Images
fabiopf
Images
Post by fabiopf »
Guys,
In our classic problem type we have images to illustrate the meaning of the variables, as you can see in the image below.
I am now rewriting our problem type using the new system (based in the CustomLIB library). I suppose it is not possible to add images to the tree, so what do you suggest? What is the best way to convert this old dialgo to the new problem type system?
As far as I know using the tree is not possible to add images.
fjgarate
Re: Images
Post by fjgarate »
Hi Fabio,
You are right, you can not add images in that window.
The nearest you can approach, if you think that the image is relevant, is to create some kind of window, like the one we show in this cmas2d_wizard example.
https://github.com/GiDHome/cmas2d_customlib_wizard
As you can see in the readme.md , this repository extends a customLib problemtype, with the tree, and adds a window to assign properties to the tree. In your case, you could create a window to assign the material properties. Check the step 2 and see how we take the values from the window to place them into the tree
https://github.com/GiDHome/cmas2d_custo ... definition
If you are interested, I could explain you how to create a toolbar and add a button, so you could launch your own windows that interact with the tree
Javi G
fabiopf
Re: Images
Post by fabiopf »
Hi Javi,
Many thanks for your reply. I will have a look at the repository. Yes, I would appreciate if you could explain me how to launch my own windows that interact with the tree. This method seems to be a good alternative to implement the material database, in opposition to implement it as nodes of the tree.
Best,
Fabio
Re: Images
There is a more simple option,
copy the image to a folder named images inside the problemtype
and add to the .spd the attribute
help_image="your_filename"
e.g.
then the image will appear below the contextual help text, like this
fabiopf
Re: Images
Post by fabiopf »
Thanks guys, I will try this.
