The meshing problem with different mesh size?
JasonRoy
Post by JasonRoy »
Recently I imported a complicated 3D model from other 3D-design software with extension .SLDASM (SolidWorks Assembly File) into GID, and tried to make its surface conformal and mesh it (I only need surface mesh). I think I already made it conformal for that when I check View -> Higher entities -> lines all lines are interior lines. The problem is with one component surface of this model, so I extract this component surface and save it in a single Gid file. I can mesh it successfully with setting mesh size 0.4 or larger than this value, but errors will be reported if I try to mesh it with setting mesh size smaller than 0.3. The error is : Couldn't mesh the surface. I don't know why this happens, I upload the file in .rar format, please check it and help to fix it.
Thank you very much!
Re: The meshing problem with different mesh size?
The attachment is missing, try again.
Maybe the .rar extension is not allowed and must be attached as zip?
or maybe the problem is the file size (I think that the current limit is 5MB)
