The meshing problem with different mesh size?
Posted: Tue Mar 23, 2021 9:32 am
Recently I imported a complicated 3D model from other 3D-design software with extension .SLDASM (SolidWorks Assembly File) into GID, and tried to make its surface conformal and mesh it (I only need surface mesh). I think I already made it conformal for that when I check View -> Higher entities -> lines all lines are interior lines. The problem is with one component surface of this model, so I extract this component surface and save it in a single Gid file. I can mesh it successfully with setting mesh size 0.4 or larger than this value, but errors will be reported if I try to mesh it with setting mesh size smaller than 0.3. The error is : Couldn't mesh the surface. I don't know why this happens, I upload the file in .rar format, please check it and help to fix it.
Thank you very much!
