Mesh of a vault
jlsp
Mesh of a vault
Post by jlsp »
I’m new in GID and I’m modeling a vault (A quarter of a square modulus of a Jujol work) to analyze the isotropic damage, using GID + Opensees interface.
From what I've seen, I need to use hexahedral elements to analyze isotropic damage, but these elements do not allow me to mesh volumes with triangular or trapezoidal surfaces, which are what I have in the model.
Is there anything that can be done to fix this?
Thank you very much
Re: Mesh of a vault
Structured meshes of hexahedra are difficult to be created for a general shape (sometimes near impossible for complex shapes)
You must somehow manually divide your geometry volume in volumes of six faces (topologically bricks)
or at least in semi-structured volumes (a surface extruded in a direction), then and generate unstructured quadrilaterals on this top-bottom surfaces and a structured number of divisions in the extruding direction.
This is the power of unstructured tetrahedra/triangles, its capability to fit a complex shape.
If do you want attach a zip of your model and maybe I can provide you more specific advices
jlsp
Re: Mesh of a vault
Post by jlsp »
Thanks Escolano for your answer.
Attached a zip of the GID model.
I think this should be analyzed with shell elements, but for isotropic damage they are not available in GID + Opensees and in Kratos I don't know.
volta_1.zip
(160.05 KiB) Downloaded 232 times
Re: Mesh of a vault
Your geometry was near to be semi-structured, all volumes are semi-structured (are a kind of extrusion: two opposite equivalent surfaces joined with lateral surfaces of 4-sides).
Only two volumes donesn't mach this pattern: I have modified these volumes (layer blue) and now all is semi-structured
Then can mesh it with hexahedra with
Mesh->Semi-structured->Volumes->Assign number of divisions in structured direction
and I have set 2 divisions and selected all volumes
then
Mesh->Element type->Hexahedra
and then generate a mesh with some size (e.g. 0.02 in my picture)
I attach also my modified model:
volta_1_modified.gid.zip
(940.15 KiB) Downloaded 208 times
But take into account that in general won't be possible do it, only in this special case where the shape is like a shell.
jlsp
Re: Mesh of a vault
Post by jlsp »
Great, I'll try to complete the analysis. Let's see if I get it
Thank you very much
