No subject
Guest
No subject
Post by Guest »
we are not SAFIR users
Have a look to the SAFIR input file written by GiD, maybe you will be able
to see what the problem is (the SAFIR manual must describe its input file)
[mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Nina Kristine
Reitan
Enviado el: lunes, 26 de mayo de 2014 12:17
Asunto: [GiDlist] GiD 11.0.7 and SAFIR
I am quite new in this field and am now trying out the trial version of
Gid11.0.7 for SAFIR. I have used the GiD to create a 2D object (a 2d
cylinder consisting of several layers of materials), and I would like to run
the problem type Safir_thermal_2d. I use HC temperature curve for exposure
on the outer layer.
I run into the following problems:
1. When I simplify the object (one layer of material) and use HC exposure,
the temperature (I have defined an initial temperature of 20 deg C) at a
certain thickness of the layer gets lower than 20 deg C).
2. When I use the complex layer and HC exposure, the temperature at all
spatial coordinates and at all times, stays at 20 dec C.
3. When I chose "calculate window" and "start", the software "hangs".
I would be very grateful any help on this issue.
------=_NextPart_000_044D_01CF78DE.FEFC1580
Content-Type: text/html;
charset="us-ascii"
html xmlns:v=3D"urn:schemas-microsoft-com:vml" =
xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns:m=3D"http://schemas.microsoft.com/office/2004/12/omml" =
xmlns=3D"http://www.w3.org/TR/REC-html40"headMETA =
HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii"meta name=3DGenerator content=3D"Microsoft Word 14 =
(filtered medium)"style!--
/* Font Definitions */
@font-face
{font-family:Calibri;
panose-1:2 15 5 2 2 2 4 3 2 4;}
@font-face
{font-family:Tahoma;
panose-1:2 11 6 4 3 5 4 4 2 4;}
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{margin:0cm;
margin-bottom:.0001pt;
font-size:11.0pt;
font-family:"Calibri","sans-serif";}
a:link, span.MsoHyperlink
{mso-style-priority:99;
color:blue;
text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
color:purple;
p.MsoAcetate, li.MsoAcetate, div.MsoAcetate
mso-style-link:"Texto de globo Car";
margin:0cm;
font-size:8.0pt;
font-family:"Tahoma","sans-serif";}
span.TextodegloboCar
{mso-style-name:"Texto de globo Car";
mso-style-link:"Texto de globo";
span.EstiloCorreo19
{mso-style-type:personal;
color:windowtext;}
p.BalloonText, li.BalloonText, div.BalloonText
{mso-style-name:"Balloon Text";
mso-style-link:"Balloon Text Char";
margin:0cm;
font-size:11.0pt;
span.BalloonTextChar
{mso-style-name:"Balloon Text Char";
mso-style-link:"Balloon Text";
span.EstiloCorreo22
{mso-style-type:personal-reply;
color:#1F497D;}
.MsoChpDefault
{mso-style-type:export-only;
font-size:10.0pt;}
@page WordSection1
{size:612.0pt 792.0pt;
margin:70.85pt 70.85pt 70.85pt 70.85pt;}
div.WordSection1
{page:WordSection1;}
--/style!--[if gte mso 9]xml
o:shapedefaults v:ext=3D"edit" spidmax=3D"1026"
/xml![endif]--!--[if gte mso 9]xml
o:shapelayout v:ext=3D"edit"
/o:shapelayout/xml![endif]--/headbody lang=3DEN-US link=3Dblue =
vlink=3Dpurplediv class=3DWordSection1p class=3DMsoNormalspan =
style=3D'color:#1F497D'Hello Nina,o:p/o:p/span/pp =
style=3D'color:#1F497D'o:p /o:p/span/pp =
class=3DMsoNormalspan style=3D'color:#1F497D'Really you must ask =
these questions to the SAFIR developers,o:p/o:p/span/pp =
class=3DMsoNormalspan style=3D'color:#1F497D'From the GiD team we =
don’t know what is doing this code for its calculation, we are not =
SAFIR users o:p/o:p/span/pp class=3DMsoNormalspan =
class=3DMsoNormalspan style=3D'color:#1F497D'Have a look to the SAFIR =
input file written by GiD, maybe you will be able to see what the =
problem is (the SAFIR manual must describe its input =
file)o:p/o:p/span/pp class=3DMsoNormalspan =
style=3D'color:#1F497D'Regardso:p/o:p/span/pp =
class=3DMsoNormalspan style=3D'color:#1F497D'Enrique =
Escolanoo:p/o:p/span/pp class=3DMsoNormalspan =
style=3D'color:#1F497D'o:p /o:p/span/pdivdiv =
style=3D'border:none;border-top:solid #B5C4DF 1.0pt;padding:3.0pt 0cm =
0cm 0cm'p class=3DMsoNormalspan lang=3DES =
style=3D'font-size:10.0pt;font-family:"Tahoma","sans-serif"'De:/span/=
bspan lang=3DES =
style=3D'font-size:10.0pt;font-family:"Tahoma","sans-serif"' =
gidlist-bounces at listas.cimne.upc.edu =
[mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Nina =
Kristine ReitanbrEnviado el: lunes, 26 de mayo de 2014 =
12:17brPara: gidlist at listas.cimne.upc.edubrAsunto: =
[GiDlist] GiD 11.0.7 and SAFIRo:p/o:p/span/pp =
class=3DMsoNormalspan lang=3DESo:p /o:p/span/pp =
class=3DMsoNormalI am quite new in this field and am now trying out the =
trial version of Gid11.0.7 for SAFIR. I have used the GiD to create a 2D =
object (a 2d cylinder consisting of several layers of materials), and I =
would like to run the problem type Safir_thermal_2d. I use HC =
temperature curve for exposure on the outer layer.o:p/o:p/pp =
class=3DMsoNormalo:p /o:p/pp class=3DMsoNormalI run into =
the following problems:o:p/o:p/pp class=3DMsoNormal1. When I =
simplify the object (one layer of material) and use HC exposure, the =
temperature (I have defined an initial temperature of 20 deg C) at a =
certain thickness of the layer gets lower than 20 deg =
C).o:p/o:p/pp class=3DMsoNormal2. When I use the complex layer =
and HC exposure, the temperature at all spatial coordinates and at all =
times, stays at 20 dec C.o:p/o:p/pp class=3DMsoNormal3. When I =
chose "calculate window" and "start", the software =
"hangs".o:p/o:p/pp =
class=3DMsoNormalo:p /o:p/pp class=3DMsoNormalI would be =
very grateful any help on this issue. o:p/o:p/p/body/html
------=_NextPart_000_044D_01CF78DE.FEFC1580--
