[GiDlist] Error in constructor
Mire Marjanovic
Post by Mire Marjanovic »
Hello GiD team,
After reading the Post.Res file of my model, when I want do display the Deformation, I obtain the following error:
Error: Error in constructor: domain error: argument not in valid range.
Everything was working well, I have interpreted the results, and this error occured suddenly, and I don't know the reason. I have attached the post.res file, as well as error.log file. Any help would be very useful. It is now happening with all my models.
Thanks in advance,
M.Marjanovic
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131024/06ece0fc/attachment-0001.htm
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131024/06ece0fc/attachment-0003.obj
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131024/06ece0fc/attachment-0004.obj
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131024/06ece0fc/attachment-0005.obj
Please, in general not attach only the result file, the mesh is also
necessary to open in.
I don't know what or when is happening the error, in any case it seems that
the problem is because GiD is suggesting an scale factor for the
deformation=0
and then the slidebar showed from the icons toolbar is created with
resolution=0 and the error is raised.
We have fixed the code for next developer version 11.1.7d (available soon)
to avoid the error also if this case happen.
[mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Mire Marjanovic
Enviado el: jueves, 24 de octubre de 2013 12:26
Asunto: [GiDlist] Error in constructor
Hello GiD team,
Thanks in advance,
M.Marjanovic
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131024/6a61aece/attachment.htm
rogelio diaz
[GiDlist] Close session of GiD
Post by rogelio diaz »
In my GiD of Xubuntu when I am meshingthe process of meshing doesn´t finish the GiD close before tha it finishes I need a solution because i need to mesh a part in it Thank you i wait a solution
GiD PROFESSIONAL version 11.0.3 My license will expired in may 2014
------------ próxima parte ------------
Se ha borrado un adjunto en formato HTML...
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131024/52f3313b/attachment.htm
Is GiD crashing always, e.g. meshing a square of 1x1, or only with some
model?
Then send us the model.
You can also try a more recent version: the last official is v 11.0.5, and
the last developer is v 11.1.6d
[mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de rogelio diaz
Enviado el: jueves, 24 de octubre de 2013 20:25
Para: gidlist at listas.cimne.upc.edu; gid at cimne.upc.edu
Asunto: [GiDlist] Close session of GiD
Thank you
i wait a solution
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131024/463c7b9e/attachment.htm
rogelio diaz
[GiDlist] Mesh
Estamos tratando de mallar este elemento.
ya revisamos el CAD y no tiene interferencias pero aunque cambiamos el tamaño de malla no logramos finalizar. Podria darle una checada y darnos sus recomendaciones.
Gracias
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131029/1f939bac/attachment-0001.htm
Se ha borrado un mensaje que no est? en formato texto plano...
Nombre : brazo6.rar
Tipo : application/octet-stream
Tama?o : 2644519 bytes
Descripci?n: no disponible
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131029/1f939bac/attachment-0001.obj
rogelio diaz
[GiDlist] Meshing
Tenemos mas problemas con el mallado al colocarle cargas a la pieza no podemos mallar volumenes se queda hasta el volumen 80 de 192 entonces queremos recomendaciones para este problema y si pudieran mallarlo y si nos pueden apoyar con los pasos se les agradecería mucho.
muchas gracias le mando el modelo CAD ya revisado por GiD y dice que no hay ningun problema con el modelo. Esto lo estamos usando en ubuntu
gracias
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131030/5c4d74c5/attachment-0001.htm
Nombre : prueba 5.rar
Tama?o : 2530950 bytes
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131030/5c4d74c5/attachment-0001.obj
rogelio diaz
[GiDlist] Peso Propio
Como puedo ver las reacciones producidas en un modelo si no quiero aplicarle ninguna carga solo el peso propio y como aplico este peso.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131113/c5f76c3b/attachment.htm
Hi Rogelio,
This list is to answer questions about GiD itself, not to answer questions
of problemtypes,
and it is better if possible to do it in English, to share the information
with more people.
Probably you don’t know well as user the difference between GiD and a
problemtype.
GiD doesn’t has any solver included, like the ‘structural solver’ that you
talk about.
A problemtype is like a plugin, developed by other people, that provide a
calculation programs and its interface with GiD.
Only the people that develop each problemtype could ask questions about
what his program does !!
Which is the problemtype used in your case? Ramseries/RamSolid(CompassFEM)?
Kratos? Another?
The answer depends on each case.
If you are using RamSeries , to apply self-weight:
1-you must set the gravity direction (default –Z)
2-You must define a material and set its ‘specific weigth’ or use some
predefined material, and assign this material to the group of entities made
of them.
3-In some loadcase you must apply a ‘self-weight load’ to a group of
entities (e.g. a group of all volumes for a solid simulation)
Then, after generate the mesh and calculate you could see its results.
CompassFEM has two kinds of postprocess tools: the ‘GiD standard
postprocess’ and ‘its own postprocess’.
I think that in both cases you can see the reactions (where you applied
displacement restrictions) drawn as vectors, listing its values, etc. and
this program add some extra tool to select a collection of restricted nodes
and sum its vector forces (to check that the equilibrium is matched)
Enviado el: miércoles, 13 de noviembre de 2013 19:31
Asunto: [GiDlist] Peso Propio
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131113/41aed019/attachment.htm
Seungil Kim
[GiDlist] how to create a surface on a sphere
Post by Seungil Kim »
Dear Sir,
I have four curves on a unit sphere.
When I used "Create NURBS surface" to create a surface bounded by the four
curves,
I expected a surface on a surface but it doesn't seem to be a part of
sphere..
Is it possible to create a spherical surface when the four bounding curves
are on a sphere?
Seungil.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131123/2d411b34/attachment.htm
If you create a surface defined only 'by its boundary lines' then the shape
of the surface must match these lines, but the inner shape is freely created
(by a kind of coons or bicubical interpolation). It shape won't necessarily
be what you are expecting, e.g. won't be spherical
You can create a perfect spherical surface by revolution with extrusion
(copy tool),
but you must know its revolution axis (two coordinates to define it), and
have some curve on the surface to be extruded (e.g. an arc)
If the 'full surface' doesn't has the required lines as boundary, then you
can create a trimmed surface, trimming the 'base surface' with its boundary
lines.
[mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Seungil Kim
Enviado el: viernes, 22 de noviembre de 2013 16:11
Asunto: [GiDlist] how to create a surface on a sphere
Dear Sir,
curves,
sphere..
are on a sphere?
Seungil.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20131122/6c112746/attachment.htm
