[GiDlist] conflict between 32 bit and 64 bit
Yu Li
Post by Yu Li »
Dear GID list:
Now I encounter a problem as the following:
I used Gid 8.0 on my old computer which is 32 bit and was installed with Gid 8.0.
Now I need to open the results in my new computer which is 64 bit.
I tried different version of GID with either 32 bit or 64 bit, however none of them can open my previous results correctly. All of then show an error message "Couldn't assign GaussPoints 'EL_2DLQ' to any mesh".
The mesh doesn't appear on the screen.
Does anyone know how to solve this problem? Thank you very much!
Li
Performance Assessments (PAS)
Institute for Environment, Health, and Safety (EHS)
Belgian Nuclear Research Centre (SCK*CEN)
Boeretang 200
B-2400 Mol
Belgium
Tel: +32+14333237
Tel(mob): +32+495457125
lyu at sckcen.bemailto:lyu at sckcen.be
[http://www.sckcen.be/images/disclaimer/sckcen2.png] Consider the environment before you print
Denk aan het milieu voor u deze e-mail print
Pensez ? l'environnement avant d'imprimer
[http://www.sckcen.be/images/disclaimer/tree.png]
[http://www.sckcen.be/images/disclaimer/footer.png]
SCK*CEN Disclaimer: http://www.sckcen.be/en/Legal-aspects/E-mail-disclaimer
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130916/e3cea61e/attachment.htm
Dear Li,
The problem is not the use of a x32 or x64 platform. The results file must
be equal and any GiD after version 8.0 must able to read it.
In fact you can install the same GiD version 8.0 x32 in your new platform
x64
(if it is a Linux platform maybe must install also the support for x32
applications. On Windows x64 you can run by default x32 applications also)
Probably the .res file or the mesh is corrupted.
It is ASCII or binary? What was your operating system?
If do you want you can send my (directly to escolano at cimne.upc.edu , not to
GiDList) and I can have a look.
[mailto:gidlist-bounces at listas.cimne.upc.edu] En nombre de Yu Li
Enviado el: lunes, 16 de septiembre de 2013 15:05
Asunto: [GiDlist] conflict between 32 bit and 64 bit
Dear GID list:
8.0.
message “Couldn't assign GaussPoints 'EL_2DLQ' to any mesh”.
The mesh doesn’t appear on the screen.
Li
Belgian Nuclear Research Centre (SCK•CEN)
Boeretang 200
B-2400 Mol
Belgium
Tel: +32+14333237
lyu at sckcen.be
Imagen quitada por el remitente.
Pensez à l'environnement avant d'imprimer
SCK•CEN Disclaimer:
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130919/8d832691/attachment.htm
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130919/8d832691/attachment.jpeg
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130919/8d832691/attachment-0001.jpeg
Name: not available
Type: image/jpeg
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130919/8d832691/attachment-0002.jpeg
