[GiDlist] Why RamDebugger not works?
刘力风
Post by 刘力风 »
Hello guys,
Gid have Ramdebugger which is said to be able to debugging TCL in Dataà
Problem Type àDebugger.
I tried to use RamDebugger per following course
http://www.gidhome.com/images/news/gidconf/2004/courses/09-Debugging%20tcl%2
0code.pdf
but nothing happened. The Debugger seems not work? Anybody know the reason.
How can I debug in RamDebugger? I am using Gid 10.0.9
Michael Liu
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130321/fe4b9d17/attachment.htm
You must open RamDebugger (e.g. press F12 in GiD or from the Data-Problemtype-Debugger... menu)
then open the Tcl file you want to debug,
and then press F5 in RamDebugger to start debugging (and you can set breakpoints F9 to stop the flow and see/change variables)
Sent: Thursday, March 21, 2013 10:34 AM
Subject: [GiDlist] Why RamDebugger not works?
Hello guys,
Gid have Ramdebugger which is said to be able to debugging TCL in DataàProblem Type àDebugger.
I tried to use RamDebugger per following course http://www.gidhome.com/images/news/gidconf/2004/courses/09-Debugging%20tcl%20code.pdf
but nothing happened. The Debugger seems not work? Anybody know the reason. How can I debug in RamDebugger? I am using Gid 10.0.9
Michael Liu
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130321/bd76c7cf/attachment.htm
