[GiDlist] problems import DEM file in GiD
Marco Giometto | EPFL
Post by Marco Giometto | EPFL »
I'm not managing to import a DEM file in GiD v.11.0.3. I'm using the GiD
interface for the library GDAL to import files in /ARC/INFO ASCII GRID
/format (see attachment) and I'm getting the following error:/
STACK TRACE FOR ERROR:
Bad file handle
while executing
"gdal_get_count $fp"
(procedure "GDAL::Read" line 22)
invoked from within
"GDAL::Read $filename"
(procedure "GDAL::ReadW" line 7)
invoked from within
"GDAL::ReadW"
invoked from within
".gid.menu.button0.m.m.6 invoke active"
("uplevel" body line 1)
invoked from within
"uplevel #0 [list $w invoke active]"
(procedure "tk::MenuInvoke" line 50)
invoked from within
"tk::MenuInvoke .gid.menu.button0.m.m.6 1"
(command bound to event)
Anyone has already imported a DEM file and could give me some hints on
how to do so?/
/Best regards,
Marco Giometto
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130114/9ad7e055/attachment-0001.htm
ncols 4
nrows 6
xllcorner 0.0
yllcorner 0.0
cellsize 50.0
NODATA_value -9999
-9999 -9999 5 2
-9999 20 100 36
3 8 35 10
32 42 50 6
88 75 27 9
13 5 1 -9999
Type: image/png
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130114/9ad7e055/attachment-0001.png
It seems a problem of the compilation of the GDAL package on Linux, at least it works well with the Windows x32 version
Which version of GiD 11.0.3 are you using: Linux x32 or x64? and what is your operating system (e.g. Ubuntu x.x, etc)?
Sent: Monday, January 14, 2013 1:06 PM
Subject: [GiDlist] problems import DEM file in GiD
I'm not managing to import a DEM file in GiD v.11.0.3. I'm using the GiD interface for the library GDAL to import files in ARC/INFO ASCII GRID format (see attachment) and I'm getting the following error:
Bad file handle
while executing
invoked from within
invoked from within
"GDAL::ReadW"
invoked from within
invoked from within
invoked from within
Anyone has already imported a DEM file and could give me some hints on how to do so?
Marco Giometto
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130114/454126ef/attachment.htm
Hello Enrique,
I'm using Linux x64, OS is ubuntu 12.04.
Best,
Marco
*From:* Marco Giometto | EPFL mailto:marco.giometto at epfl.ch
*To:* gidlist at listas.cimne.upc.edu
mailto:gidlist at listas.cimne.upc.edu
*Sent:* Monday, January 14, 2013 1:06 PM
*Subject:* [GiDlist] problems import DEM file in GiD
/ARC/INFO ASCII GRID /format (see attachment) and I'm getting the
following error:/
Bad file handle
while executing
invoked from within
invoked from within
"GDAL::ReadW"
invoked from within
invoked from within
invoked from within
hints on how to do so?/
/Best regards,
Marco Giometto
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130114/fb5823c9/attachment.htm
We have fixed the problem with the GDAL package on Linux,
GDAL import will work well on next GiD 11.0.4 official and 11.1.3d developer versions (there is not a specific date to release these versions, about a month maybe)
Sent: Monday, January 14, 2013 3:52 PM
Subject: Re: [GiDlist] problems import DEM file in GiD
Bad file handle
while executing
invoked from within
invoked from within
"GDAL::ReadW"
invoked from within
invoked from within
invoked from within
Marco Giometto
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20130118/5f15caf3/attachment.htm
