Hi Anna,
Thanks for the reply.
Actually, I realized it is part of a bigger problem that I am struggling
with. I have been trying to get a proper solution but haven’t yet. Any
assistance would be really helpful.
Actually my analysis happens in two parts. For e.g. first there is a large
deformation of the body (no deformation factor is needed in the result) and
then there is a thermal shrinkage/expansion on the same body after the large
deformation. So there are two .post.res file with two sets of displacements.
Since GiD by default calculates the deformation based on the original mesh –
for the second analysis, I actually print out the total displacement w.r.t
original geometry. So, it is the large deformation displacement + the small
shrinkage. Now this causes the problem that I cannot use a deformation
factor just for viewing the small shrinkage because GiD applies the
deformation to the total displacement and plots are weird.
How can I solve this problem? Is there a way that I can write an ascii mesh
which can be used as reference for the small displacement instead of having
to use the original mesh information?
Thanks for your support,
gidlist-bounces at listas.cimne.upc.edu
[mailto:
gidlist-bounces at listas.cimne.upc.edu] On Behalf Of Anna Monros
Sent: Tuesday, September 21, 2010 11:42 AM
To:
gidlist at listas.cimne.upc.edu
Subject: Re: [GiDlist] Animation for Small Deformation
Dear Shriram,
I don't understand exactly what you mean.
Your analysis has only one step or several steps?
If you have several steps, when you choose a deformation factor and you
perform an animation you should see each step deformed with that factor.
El 17/09/2010 22:01, Shriram escribió:
I have a small deformation analysis (thermal shrinkage/expansion) over time.
So I have results for the displacements over time. But since it’s a thermal
problem the deformation is really small, I use a deformation factor to see
the deformation.
I want to animate the deformation with the factor. The animation doesn’t do
that. It deforms with the factor in the animation but the animation is
without any factor.
Is there a way to achieve animation with deformation factor?
Anna Monros Bellart
Campus Nord UPC - C1 building - C2 Office
Gran Capità s/n - 08034 Barcelona
AVISO IMPORTANTE
Los datos de carácter personal contenidos en el mensaje, se registrarán en
un fichero para facilitar la gestión de las comunicaciones de CIMNE. Se
pueden ejercitar los derechos de acceso, rectificación, cancelación y
oposición por escrito, dirigiéndose a nuestras oficinas de CIMNE, Gran
Capitán s/n, Edificio C1 - Campus Norte UPC, 08034 Barcelona, España.
AVÍS IMPORTANT
Les dades de caràcter personal contingudes en aquest missatge es registraran
en un fitxer per facilitar la gestió de les comunicacions del CIMNE. Es
poden exercir els drets d'accés, rectificació, cancel•lació i oposició, per
escrit a les nostres oficines del CIMNE, Gran Capità s/n, Edifici C1, Campus
Nord UPC, 08034 Barcelona, Espanya.
IMPORTANT NOTICE
All personal data contained in this mail will be processed confidentially
and stored in a file property of CIMNE in order to manage corporate
communications. You may exercise the right of access, rectification,
deletion and objection by letter sent to CIMNE, Gran Capitán, Edificio C1 -
Campus Norte UPC, 08034 Barcelona, Spain.
URL:
http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100922/742f4831/attachment.htm
