I have the following problem: I would like to obtain in a tcl-script the
numbers of some surfaces, which are located inside a specific geometric
domain. This is just like selecting some surfaces, but based on a
tcl-script. Is there any way to do that?
Furthermore, I can not define a batch-file. Each time I declare the
batch-file in Preference, I get the shell message:
"sh: Syntax error: Bad fd number"
Is this a bug?
Georg
[GiDlist] selection
[GiDlist] GiDlist Digest, Vol 3, Issue 9. Numering nodes and
Enrique,
Thank you very much for your answer, but the problem is that I don't find where it is possible to change the variable "RenumberMethod".
Thank you very much again.
Regards.
Arturo Ramón González
Westinghouse Electric Spain
Dpto. Seguridad y Licenciamiento
Padilla 17, 28006 Madrid
Telf: (+34) 91 2106506
Fax: (+34) 91 2106540
E-mail: ramonga at westinghouse.com
Message: 1
Date: Thu, 16 Sep 2010 11:49:23 -0400
From: "Ramon Gonzalez, Arturo" Ramonga at westinghouse.com
Subject: [GiDlist] Numering nodes and elements
To: "gidlist at listas.cimne.upc.edu" gidlist at listas.cimne.upc.edu
Message-ID:
DFB5BAD48C93D34E9EA3BD235CE76A4B01079EE091 at SWEC9980.w-intra.net
Content-Type: text/plain; charset="iso-8859-1"
Good afternoon,
When I generate a mesh with GID, automatically GID numbers the nodes and the elements. I have been looking for a option that allow me renumbering the nodes and elements in a way defined for me, but I don't find it. Is there any way to do that?
Regards.
Arturo Ram?n Gonz?lez
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100916/eda27ae1/attachment.html
Message: 2
Date: Thu, 16 Sep 2010 19:17:22 +0200
Subject: Re: [GiDlist] Numering nodes and elements
Message-ID: 2FA02D517EE14F189FB491D5BA3F19BC at mediador
The nodes renumeration algorithm can be set with the variable 'RenumberMethod'
Accepted values are:
-2 : Avoid nodes and elements renumeration, entities numbers are set increasingly when they are generated.
-1 : Avoid nodes renumeration, nodes numbers are set increasingly when they are generated
0 : Geometrical algorimth, ordered by the distance to some coordinate. It is the default value
1 : Reverse Cuthill-McKee algorimth, similar to the previous one, but following element's connectivities
2 : ordered following the XYZ axes, interesting for special cases with geometry aligned to the axes
As a trick, you can write a file with GiD mesh ASCII format with your own renumeration, and import this mesh with
Mescape Files MeshRead $filename
but the boundary conditions will be lost.
Maybe we could add for next versions a GiD-Tcl command to user-renumber nodes or elements without delete and create them again.
(something like: GiD_Mesh Renumber nodes|elements {{list of old id's} {list of new id's}} )
You can use our AfterMeshGeneration Tcl-GiD event to automatically invoke your own renumeration procedure:
The prototype of this event is this (See GiD Help on Tcl/Tk customization)
It exists also an AfterRenumber Tcl-GiD event to let you know the relation between old and new numbers when a renumbering
proc AfterRenumber { useof leveltype renumeration } {
AfterRenumber : will be called after renumber the geometry or the mesh (to update for example fields storing entity identifiers)
useof : could be GEOMETRYUSE or MESHUSE
leveltype: the kind of entity that was renumbered.
Geometry: must be ALL_LT.
Mesh: could be NODE_LT or ELEM_LT.
renumeration:
Geometry: four sublists with the old and new idenfiers for points, lines, surfaces and volumes.
Mesh: a sublist with the old and new identifiers for nodes or elements.
Sent: Thursday, September 16, 2010 5:49 PM
Good afternoon,
Regards.
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100916/b28076d9/attachment-0001.htm
End of GiDlist Digest, Vol 3, Issue 9
Regards.
Message: 1
Message-ID:
Good afternoon,
Regards.
Message: 2
renumeration:
Good afternoon,
Regards.
You can write in the command line
escape Utilities Variables
and pick the right mouse button to see the variables in the contextual menu
escape Utilities Variables RenuberMethod 0
Note: from Tcl can set/ask a the value of GiD variables with the command
GiD_Set varname ?value?, e.g
GiD_Set RenuberMethod 0
But probably any of our node numbering algorithm will exactly fit your
requirements.
Off course your solver can internally do its own renumbering.
Sent: Friday, September 17, 2010 1:56 PM
Subject: Re: [GiDlist] GiDlist Digest, Vol 3,Issue 9. Numering nodes and
elements
Enrique,
Regards.
Message: 1
Message-ID:
Good afternoon,
any way to do that?
Regards.
URL:
Message: 2
'RenumberMethod'
are generated
of new id's}} )
renumeration:
Good afternoon,
any way to do that?
Regards.
URL:
requirements.
elements
Enrique,
Regards.
Message: 1
Message-ID:
Good afternoon,
any way to do that?
Regards.
URL:
Message: 2
'RenumberMethod'
are generated
of new id's}} )
renumeration:
Good afternoon,
any way to do that?
Regards.
URL:
