I have GiD 8.2.0b running on a x64 Gentoo/Gnome. When I'm running scripts via the TCL-extension to generate a bunch of files, GiD pops up its meshing and collapsing status windows on every of the four desktops. Also the collapsing popup grabs the focus of any application when running in the same desktop.
This is very annoying, you cannot work while GiD is working.
Chistoph Noelle
Disclaimer
This message might contain confidential and privileged information and is intended only for the individuals or entities to which it is addressed. It should not be copied, reviewed, retransmitted, disseminated or otherwise used by persons or entities other than the intended recipient. If this message was received in error, please contact the sender and delete the material from your computer system(s).
Receipt of this message does neither generate any right of further use nor entitles the recipient to file and/or obtain any intellectual property rights based thereon.
[GiDlist] popup windows in all desktops
