No subject
Guest
No subject
Post by Guest »
Specify the condition sets:
1. 0 0 1 0 1 ----Condition1
2. 1 1 1 0 1 ----Condition2
3. 1 1 1 1 1 ----Condition3
Assign the conditions to the supports
Node Condition set
1 1
2 1
3 2
4 2
5 2
6 3
7 3
8 1
--- Mihai TEODORESCU
mihai.teodorescu at prevost-industries.com wrote:
Thank you. This is a good point start.
Supposing I apply the condition
Point_Déplacement_imposé first with the
arguments dx=0 dy=0 dz=0 and the with the arguments
dx=10 dy=0 dz=10
using the a procedere to find out all the
conditions, sort them and
printing only once each condition is OK.
But If I apply twice the condition
Point_Déplacement_imposé with the
some arguments dx=0 dy=0 dz=0 using the method you
proposed me I will
get only one condition in my bas file. For my
problem I need to be able
to print individualy each condition (the two I
applied and not for each
point), even if they have the same parameter.
The reasons why I need individualy acces to each
condition are driven by
the FEM code I use.
Supposing that I want simulate a stamping process. I
need to aplpy some
conditions to block parts in space and other
conditions to move down the
punch. Normaly the conditions are different. By
maybe in some cases they
will have the some values in the firts step. The
some is true for
forces. I need to be able to apply forces with the
some values but one
will constant over time and other will evolue
fonction of time.
Mihai TEODORESCU
Email: mihai.teodorescu at prevost-industries.com
Do you Yahoo!?
Yahoo! Tax Center - forms, calculators, tips, more
http://taxes.yahoo.com/
