[GiDlist] Can I get the time consuming to generate mesh?
CHEN Ningning
Post by CHEN Ningning »
Can I get the time which used to generate mesh?
How can I do?
        CHEN Ningning
        xjtucnn at 163.com
          2010-05-14
Lluis Mesquida
[GiDlist] can't read "goux"
Post by Lluis Mesquida »
Hi, I'm using Tdyn 10.3.0
I have a problem when i try to lunch Calculations in a model which I have Termal (solid and fluid), advection (solid and fluid) an fluid Flow.
When i try to launch the calculation after meshing, occurs a problem with this message:
Error when preparing data for analisys can't read "goux". no such variable.
I don't know what could be the problem, becuase in other examples without advection the same problem run without problems.
Anybody knows why i can't run all this toghether?
_________________________________________________________________
Recibe en tu HOTMAIL los emails de TODAS tus CUENTAS. + info
http://www.vivelive.com/hotmail-la-gente-de-hoy/index.html?multiaccount
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100514/1c5425f9/attachment.htm
Daniel Sa
Post by Daniel Sa »
Hello Lluis,
Please download the latest Tdyn version (10.3.2b) from our web (
http://www.compassis.com/compass/en/Productos/Tdyn/Descargar).
If the problem persists, please contact with me directly, so i can check the
model.
Daniel
On Fri, May 14, 2010 at 1:00 PM, Lluis Mesquida
this message:
"Del lado oscuro de Internet protegido estar puedes." ¡Descárgate gratis
Internet Explorer 8! [url=http://www.quelafuerzateacompa%C3%B1e.com]http://www.quelafuerzateacompañe.com[/url]
Daniel Sá López
Ingeniero Naval
COMPASS Ingeniería y Sistemas S.A.
C/ Tuset 8, 7º 2ª
Barcelona 08006
T: (+34) 93.218.19.89
F: (+34) 93.396.97.46
E: danielsa at compassis.com
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100514/efcfb58b/attachment.htm
You can implement the GiD-tcl events raised before and after the generation of the mesh, and measure the time with some Tcl command, for example
proc BeforeMeshGeneration { elementsize } {
set ::TimeStart [clock seconds]
set now [clock seconds]
WarnWinText "Meshing time: [expr $now-$::TimeStart] seconds"
To use it, you can copy these procedures in a .tcl file and source it
Or as a trick simply paste the code in the lower command line, preceded by -np- and an space (-np- want to mean 'non-process' and must be followed by some tcl code.
Sent: Friday, May 14, 2010 5:00 AM
Subject: [GiDlist] Can I get the time consuming to generate mesh?
How can I do?
        CHEN Ningning
        xjtucnn at 163.com
          2010-05-14
GiDlist at gid.cimne.upc.edu
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20100514/77ce8023/attachment.htm
abelcs
Post by abelcs »
Dear Chen,
Now there is no tool to know the time used to generate the mesh inside GiD. The only way for obtaining this information is to control the times of gid process by the system tools (Windows, etc.).
Kind regards,
ABEL
AVISO IMPORTANTE
Los datos de carácter personal contenidos en el mensaje, se registrarán en un fichero para facilitar la gestión de las comunicaciones de CIMNE. Se pueden ejercitar los derechos de acceso, rectificación, cancelación y oposición por escrito, dirigiéndose a nuestras oficinas de CIMNE, Gran Capitán s/n, Edificio C1 - Campus Norte UPC, 08034 Barcelona, España.
AVÍS IMPORTANT
Les dades de caràcter personal contingudes en aquest missatge es registraran en un fitxer per facilitar la gestió de les comunicacions del CIMNE. Es poden exercir els drets d'accés, rectificació, cancel·lació i oposició, per escrit a les nostres oficines del CIMNE, Gran Capità s/n, Edifici C1, Campus Nord UPC, 08034 Barcelona, Espanya.
IMPORTANT NOTICE
De: gidlist-admin at gid.cimne.upc.edu [mailto:gidlist-admin at gid.cimne.upc.edu] En nombre de CHEN Ningning
Enviado el: viernes, 14 de mayo de 2010 5:00
Asunto: [GiDlist] Can I get the time consuming to generate mesh?
How can I do?
        CHEN Ningning
        xjtucnn at 163.com
          2010-05-14
