GiD 13.1.11d on macOS not starting
vjagodnik
Post by vjagodnik »
Dear all,
I am trying to start a GiD version 13.1.11d on my MacBook Pro but without success.
I constantly get a message that the software was not installed from App store, but when I change the security settings within system Preferences and start program again, GiD does not open.
I have tried with lower version, 13.1.10d.; opened GiD without any problem. Used the ReadMe file form 13.1.10d installation folder hoping it will work for 13.1.11d but no luck.
Hope someone has an idea how to solve it.
With kind regards
vedran
Re: GiD 13.1.11d on macOS not starting
Have you tried with current 14.0.x official version?
https://www.gidhome.com/download/offici ... l-mac-os-x
(on the other hand the 13.1.11d developeer will have very similar features than the 13.1.10d, you can use it also)
vjagodnik
Post by vjagodnik »
Thank you for the advice. Unfortunately I am limited to version 13.1.11d. This is the version that I have to have in order to use Kratos, at least I think so. I would be glad to be mistaken. Also, I have a license for version 13.
With kind regards
V
For macOS the currently (compiled) available Kratos version is the 6.0.0
For Linux x64 and Windows x64 there is available a new Kratos 7.0.2 version
As you pointed, Kratos 6.0.0 is declaring that it require GiD 13.1.11d or higher, but maybe the GiD version 13.1.10d is also valid, at least for most features (but I don't know if this problemtype using some new command appeared in GiD 13.1.11d)
Try simply editing the file 'Kratos.xml' and changing
<MinimumGiDVersion>13.1.11d</MinimumGiDVersion>
by 13.1.10d
In fact when loading the problemtype it raise the message that complain about the GiD version, but it is possible to continue trying with the current version
vjagodnik
Post by vjagodnik »
Will try later today.
Thank you for the advice and hints. It is always fun to edit ini files
With kind regards
Vedran
Post by miguel »
Hi Vedran,
please try the latest developer version 14.1.6d just uploaded today at:
https://www.gidhome.com/download/develo ... /mac-os-x/
And tell us how it went.
Which macOS are you using?
thanks,
vjagodnik
Post by vjagodnik »
Thank you miguel,
I will try it.
The only problem with this version is that i do not have an licence for version 14.
Vedran
At least to try it you can use a trial one month password (until three times)
http://www.gidhome.com/purchase/passwords
