In the water retention van Genuchten model ICL=6, ITYCL=1;
Is the P in the formula the air entry value? I noticed that P=P0(sigma/sigma0). What is sigma here? There are explanations for P0 and sigma0 in the manual as following, but not sigma:
Po (MPa): Measured P at certain temperature
sigma0 (N m-1): Surface tension at temperature in which Po was measured (usually ÃÆ’o=0.072 N/m at 20ºC)
Thank you
van Genuchten model ITYCL=1
Moderator: CODE_BRIGHT Team
