I'm using GiD version 9.0.2 with SAFIR version 2013.b.2.
It used to work for the last days but since today I get errors when I try to start my calculation.
In GiD I get the process error: "No .out-file or results in .out-file found"
There is an .out-file in my working directory. At the end of that file, the following is written:
*SAFIR*
*2013b*
* 2 *
DESCRIPTION OF THE PROBLEM.
InputFile created with GiD-SAFIR_2012 Interface
Safir_Static_3D_Analysis
Mesh_from_GID-Mesher
DATA USED IN THE DIMENSIONS OF THE ARRAY.
- THERE ARE 7831 NODES.
- THERE ARE 3 GLOBAL AXES.
- THE MAXIMUM # OF D.O.F. PER NODE IS 6
- 1 CORE(S) OF THE COMPUTER WILL BE USED.
- A DYNAMIC CALCULATION WILL BE PERFORMED.
Damping coefficient: 0.000
- THERE ARE 1 LOAD VECTORS APPLIED TO THE STRUCTURE
AND 0 INCLINED SUPPORTS.
DESCRIPTION OF THE STRUCTURE.
- THERE ARE 1 DIFFERENT MATERIALS.
- THERE ARE 2508 SHELL ELEMENTS
DIVIDED INTO 5 SECTION TYPES
WITH MAX. 0 LAYERS OF RE-BARS.
EACH ELEMENT HAS 5 INTEGRATION POINTS ON THE THICKNESS.
4 INTEGRATION POINTS ON THE AREA.
ERROR from subr. ELllocate_nddl.
beam_flang command encountered instead of 'NODOFSHELL'.
Anyone knows what the solution could be?
