Hi everyone,
I am not sure if anyone has the same problems in CODE_BRIGHT as I do.
Recently I've always been disturbed by the software stability problem. In short, one day ago the model run and calculated perfectly. However, a day later, when I run it again, it simply doesn't calculate at all. When I press the "view process" menu, it shows "no information to visualize for current project".
This problem also happens when I save the current project as another one to modify on it. The "saved as" project, which is the same as the original one, doesn't run and calculate.
I cannot understand what is going on here. Hope anyone here might had this problem before?
CODE_BRIGHT stability problem
Moderator: CODE_BRIGHT Team
