The menu bar does not appear
By activating a command from one moment to another, the menu bar disappeared and only the drawing area remained on the screen. I have restarted GiD, I have uninstalled it and I have reinstalled it without any results.
Re: The menu bar does not appear
Which command did you activate? Which GiD version are you using?
You can use the "Repair GiD" option, it's a utility for applying some actions before starting GiD.
You will find it on the start button, inside the GiD folder, if you are in MS Windows system.
Try it and select the "Reset preferences" option.
This should solve the problem.
Anna, the problem is solved. Thank you
