[GiDlist] code indenting in a .bas file
Smith, Mark
Post by Smith, Mark »
Hi Gid team
is it OK to indent lines in a .bas file to make it more readable or does
this cause a problem?
mark
Please be advised that this email may contain confidential
information. If you are not the intended recipient, please notify us
by email by replying to the sender and delete this message. The
sender disclaims that the content of this email constitutes an offer
to enter into, or the acceptance of, any agreement; provided that the
foregoing does not invalidate the binding effect of any digital or
other electronic reproduction of a manual signature that is included
in any attachment.
This could cause a problem, because everything that is not a special command
starting by * is directly printed to the output file,
then your output file with have this indented lines, and it could be a
problem if the solver that must read it doesn't support this additional
spaces or tabs.
To: "gidlist" gidlist at listas.cimne.upc.edu
Sent: Tuesday, June 21, 2011 3:39 PM
Subject: [GiDlist] code indenting in a .bas file
Hi Gid team
mark
in any attachment.
Smith, Mark
Thanks Enrique.
mark
-----Original Message-----
[mailto:gidlist-bounces at listas.cimne.upc.edu] On Behalf Of Enrique
Escolano
Sent: 21 June 2011 15:08
Subject: Re: [GiDlist] code indenting in a .bas file
command starting by * is directly printed to the output file, then your
output file with have this indented lines, and it could be a problem if
the solver that must read it doesn't support this additional spaces or
tabs.
Hi Gid team
does
mark
in any attachment.
in any attachment.
