Import Autoform results
b06dAn
Post by b06dAn »
Dear GID team,
I am a stamping simulation engineer and I would like to import results from simulations obtained with Autoform.
Is it possible with GID?
Re: Import Autoform results
No, we don't know what is the format of the results file of Autoform.
Do you know if this format is publicly documented?
Then probably is relatively easy to write a plugin to allow this import in GiD
(similar to Calculix .frb results import that can be seen at <GiD>\plugins\Import\Calculix)
Maybe Autoform is able to export results in some 'useful' results format like FEMAP, TECPLOT of VTK that are implemented in GiD
