Issues in running Code_Bright Tutorial Consolidation Joint Element
Moderator: CODE_BRIGHT Team
saminrazi
Post by saminrazi »
I an trying to build and run tutorial models related to joint model : "shear hydraulic test" and "Consolidation Joint element". After running the model, following error will show up : "No results found: definitions for 4 gauss points read." with no result in post process. I attached one of models. Could you let me know how to solve the issue?
consolid.gid.zip
(81.57 KiB) Downloaded 452 times
