the problemtype.
must ask this question to this problemtype developers (you don't said =
which is the problemtype used, loaded with Data-Problemtype-xxx)
To: gidlist at listas.cimne.upc.edu=20
Sent: Thursday, January 31, 2013 12:33 PM
Subject: [GiDlist] ERROR from subr. LININTERPOL.
=20
I want to calculate a 2D thermal calculation.=20
In the model there are 2 materials: 1 standard Stealth mat and 1 User =
material.
=20
1) When I calculate this model without the VOID function, it runs =
ok.
2) But when I want to calculate with VOID in it, then I =
constantly get the following error: =20
"ERROR from subr. LININTERPOL. =20
It is not possible to find a linear interpolation for the value =
: 2293.510=20
because the maximum defined value is =
: 2000.000"
=20
It runs for the first 240 seconds and then the error appears.
=20
Any idea?
=20
Wai-Kwok
____________________________________________________________
Electronic mail messages entering and leaving Arup business
systems are scanned for acceptability of content and viruses
------=_NextPart_000_02AD_01CDFFB2.F6DAD310
Content-Type: text/html;
charset="iso-8859-1"
!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"
HTML xmlns=3D"http://www.w3.org/TR/REC-html40" xmlns:v =3D=20
"urn:schemas-microsoft-com:vml" xmlns:o =3D=20
"http://schemas.microsoft.com/office/2004/12/omml"HEAD
META content=3D"text/html; charset=3Diso-8859-1" =
http-equiv=3DContent-Type
META name=3DGENERATOR content=3D"MSHTML 9.00.8112.16450"
STYLE@font-face {
font-family: Calibri;
@page WordSection1 {size: 612.0pt 792.0pt; margin: 70.85pt 70.85pt =
70.85pt 70.85pt; }
P.MsoNormal {
MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Calibri","sans-serif"; FONT-SIZE: =
11pt; mso-fareast-language: EN-US
LI.MsoNormal {
DIV.MsoNormal {
A:link {
COLOR: blue; TEXT-DECORATION: underline; mso-style-priority: 99
SPAN.MsoHyperlink {
A:visited {
COLOR: purple; TEXT-DECORATION: underline; mso-style-priority: 99
SPAN.MsoHyperlinkFollowed {
P.MsoListParagraph {
MARGIN: 0cm 0cm 0pt 36pt; FONT-FAMILY: "Calibri","sans-serif"; =
FONT-SIZE: 11pt; mso-fareast-language: EN-US; mso-style-priority: 34
LI.MsoListParagraph {
DIV.MsoListParagraph {
SPAN.EmailStyle17 {
FONT-FAMILY: "Calibri","sans-serif"; COLOR: windowtext; mso-style-type: =
personal-compose
.MsoChpDefault {
FONT-FAMILY: "Calibri","sans-serif"; mso-fareast-language: EN-US; =
mso-style-type: export-only
DIV.WordSection1 {
page: WordSection1
OL {
MARGIN-BOTTOM: 0cm
UL {
MARGIN-BOTTOM: 0cm
/STYLE
!--[if gte mso 9]xml
o:shapedefaults v:ext=3D"edit" spidmax=3D"1026"
/xml![endif]--!--[if gte mso 9]xml
o:shapelayout v:ext=3D"edit"
/o:shapelayout/xml![endif]--/HEAD
BODY lang=3DNL bgColor=3D#ffffff vLink=3Dpurple link=3Dblue
DIVFONT size=3D2 face=3DArialYou are talking about things specific =
of the=20
problemtype that you are using to solve your 2D thermal =
calculation/FONT/DIV
DIVFONT size=3D2 face=3DArial/FONT /DIV
DIVFONT size=3D2 face=3DArialFrom GiD w/FONTFONT size=3D2 =
face=3DAriale don't=20
know anything about your materials, VOID or LININTERPOL. A/FONTFONT =
size=3D2=20
face=3DArialll these variables and messages are defined and raised by =
the=20
problemtype./FONT/DIV
DIVFONT size=3D2 face=3DArialmust ask this question to this =
problemtype=20
developers (you don't said which is the problemtype used, loaded with=20
Data->Problemtype->xxx)/FONT/DIV
DIVFONT size=3D2 face=3DArialEnrique Escolano/FONT/DIV
BLOCKQUOTE=20
style=3D"BORDER-LEFT: #000000 2px solid; PADDING-LEFT: 5px; =
PADDING-RIGHT: 0px; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px"
DIV style=3D"FONT: 10pt arial"----- Original Message ----- /DIV
DIV=20
style=3D"FONT: 10pt arial; BACKGROUND: #e4e4e4; font-color: =
black"BFrom:/B=20
A title=3DWai-Kwok.Lam at arup.com =
href=3D"mailto:Wai-Kwok.Lam at arup.com"Wai Kwok=20
Lam/A /DIV
title=3Dgidlist at listas.cimne.upc.edu=20
href=3D"mailto:gidlist at listas.cimne.upc.edu"gidlist at listas.cimne.upc.edu=
/A=20
/DIV
DIV style=3D"FONT: 10pt arial"BSent:/B Thursday, January 31, =
2013 12:33=20
PM/DIV
DIV style=3D"FONT: 10pt arial"BSubject:/B [GiDlist] ERROR from =
subr.=20
LININTERPOL./DIV
DIVBR/DIV
DIV class=3DWordSection1
P class=3DMsoNormalHello,o:p/o:p/P
P class=3DMsoNormalo:p /o:p/P
P class=3DMsoNormalSPAN lang=3DEN-USI want to calculate a 2D =
thermal=20
calculation. o:p/o:p/SPAN/P
P class=3DMsoNormalSPAN lang=3DEN-USIn the model there are 2 =
materials: 1=20
standard Stealth mat and 1 User material.o:p/o:p/SPAN/P
P class=3DMsoNormalSPAN lang=3DEN-USo:p /o:p/SPAN/P
P style=3D"TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1"=20
class=3DMsoListParagraph![if !supportLists]SPAN lang=3DEN-USSPAN=20
style=3D"mso-list: Ignore"1)SPAN=20
style=3D"FONT: 7pt 'Times New Roman'" =20
/SPAN/SPAN/SPAN![endif]SPAN lang=3DEN-USWhen I calculate =
this model=20
without the VOID function, it runs ok.o:p/o:p/SPAN/P
style=3D"mso-list: Ignore"2)SPAN=20
/SPAN/SPAN/SPAN![endif]SPAN lang=3DEN-USBut when I want to =
calculate=20
with VOID in it, then I constantly get the following error:=20
o:p/o:p/SPAN/P
P class=3DMsoListParagraphSPAN lang=3DEN-US=93ERROR from subr.=20
LININTERPOL. o:p/o:p/SPAN/P
P class=3DMsoListParagraphSPAN lang=3DEN-USIt is not possible to =
find a linear=20
: =20
2293.510 o:p/o:p/SPAN/P
P class=3DMsoListParagraphSPAN lang=3DEN-USbecause the maximum =
defined value=20
is  =
; =20
nbsp; &n=
bsp; =20
: 2000.000=94o:p/o:p/SPAN/P
P class=3DMsoNormalSPAN lang=3DEN-USIt runs for the first 240 =
seconds and then=20
the error appears.o:p/o:p/SPAN/P
P class=3DMsoNormalSPAN lang=3DEN-USAny =
idea?o:p/o:p/SPAN/P
P class=3DMsoNormalSPAN lang=3DEN-USRegards,o:p/o:p/SPAN/P
P class=3DMsoNormalSPAN =
lang=3DEN-USWai-Kwoko:p/o:p/SPAN/P/DIV
P____________________________________________________________BRElectr=
onic=20
mail messages entering and leaving Arup businessBRsystems are =
scanned=20
for acceptability of content and viruses/P
P
HR
P/P_______________________________________________BRGiDlist =
mailing=20
listBRGiDlist at listas.cimne.upc.eduBRhttp://listas.cimne.upc.edu/cgi-b=
in/mailman/listinfo/gidlistBR/BLOCKQUOTE/BODY/HTML
------=_NextPart_000_02AD_01CDFFB2.F6DAD310--
