NURBS non planar surfaces
SBO
Post by SBO »
Hi all,
I have a complex geometry for which I want to generate planar surfaces automatically. By using the command of NURBS surface and 'automate', I need to enter the number of lines necessary to generate the surfaces. When I want to generate surfaces with 6 lines for example, it creates also NURBS surfaces defined by 6 lines that are not in the same plan which is undesired ... How can I avoid this and generate only planar surfaces please ?
Samia
Re: NURBS non planar surfaces
unfortunately nowadays is not possible to prevent the creation of non planar shaped surface in the procedure that create NURBS surfaces 'automatic of n sides' .
I don't remember also any current tool or filter to easily select the non-planar (with a tolerance) surfaces.
We can study to add these features in new versions.
Now you must manually identify and delete the 'curved surfaces' that you don't want.
You can also create a user macro in Tcl scripting language to filter them (the GiD_Info parametric surface $id maincurvature or derivatives will aid you to detect curved surfaces)
SBO
Post by SBO »
Thanks for the answer, I will try the user macro!
Samia
SBO
Post by SBO »
When trying to create the user macro and use the command line with -np-, GiD doesn't react to the commands I enter ... The most basic command I tried is "-np- GiD_Info Project". It doesn't return any error message, but it doesn't return the result neither .. How can I fix this ?
I also checked the command "GiD_Geometry delete surface <args>" where <args>: num numa:numb buma:layer:layer_name. Could you please explain what is the meaning of this parameter <args> ?
Finally, I found an example of the command GiD_Info parametric Surface : "GiD_Info parametric line 26 deriv_t 0.25" I don't understand to which parameter corresponds the 0.25 ? Isn't it supposed to be something like "xyz" or "uv" ?
Samia
a command like
Code: Select all
will get the information of the project, but nothing is done with this data, probably do you want to be shown in a window.
we have for example a short name of a Tcl procedure that show a text in a window, this procedure is simply named W
try this:
Code: Select all
-np- W [GiD_Info Project]
(the [] are to evaluate a Tcl command, it is Tcl syntax)
About
where <args>: num | numa:numb | layer:layer_name.
args is a variable list of arguments, there could be different amount of arguments, with the explained meaning
e.g
Code: Select all
GiD_Geometry delete surface 3
will delete the surface id=3
Code: Select all
GiD_Geometry delete surface 3:5
will delete the surfaces with number between 3 and 5 (included)
Code: Select all
GiD_Geometry delete surface layer:hello
will delete the layers that are assigned to the layer named 'hello'
and about GiD_Info parametric it allow ask for different things of a curve or surface (the 3D point from its parameter, or the parameter closest to a 3D point, or derivatives and more... (as is explained in the GiD customization manual)
e.g
Code: Select all
will return a list with the 3 values dx dy dz of the derivative of the curve number 26 at the parameter value=0.25 (GiD curves are parametrized from 0.0 to 1.0)
Note: the parameter 0.25 is not equal to the 25% of the curve lenght. Parametrizations could be very non-uniform
