[GiDlist] Problems to postprocess in Safir
Javier Unanua
Post by Javier Unanua »
Dear colleagues;
I can not postprocess thermal models run with the code Safir. When I switch from processing to postprocessing, an error message pops up (see attached).
It follows that I can not postprocess the model, it is not loaded.
Are you aware about how to overcome such problem?
Kind regards
Javier Unanua
Senior Engineer | Fire Engineering
Arup
C/ Alcalá 54 E28014 Madrid Spain
t +34 91 523 92 76
f +34 91 521 85 75 m +34 696 23 35 31
www.arup.comhttp://www.arup.com/
____________________________________________________________
Electronic mail messages entering and leaving Arup business
systems are scanned for acceptability of content and viruses
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120524/84b31f2e/attachment-0001.htm
Type: application/vnd.openxmlformats-officedocument.wordprocessingml.document
Desc: error.docx
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120524/84b31f2e/attachment-0001.bin
Eric Tonicello
Post by Eric Tonicello »
Hi, try to send me your file, I’ll have a look at it.
Does it open in DIAMOND ?
Otherwise try to send it to safir staff
Eric Tonicello
MP Ingénieurs Conseils SA
Eric Tonicello
Civi engineer Bsc, Mas Timber structures, Cas Fire protection
Fire Safety Engineering Specialist, member of
http://www.vbsf.ch/section_romande SSPS, http://www.sfpe.org/ SFPE,
http://www.iafss.org/ IAFSS
office: info at mp-ingenieurs.ch
direct: mailto:eric.tonicello at mp-ingenieurs.ch
16, rue du Centre
CH-1023 Crissier
office: +41 21 636 09 02
fax: +41 21 635 09 40
mobile: +41 78 600 90 31
www.mp-ingenieurs.ch
De : gidlist-bounces at listas.cimne.upc.edu
[mailto:gidlist-bounces at listas.cimne.upc.edu] De la part de Javier Unanua
Envoyé : jeudi 24 mai 2012 19:08
À : gidlist at listas.cimne.upc.edu
Objet : [GiDlist] Problems to postprocess in Safir
Dear colleagues;
Kind regards
Javier Unanua
Arup
t +34 91 523 92 76
http://www.arup.com/ www.arup.com
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120525/ce9ac783/attachment.htm
Javier Unanua
Hi Eric;
Yes, I can open the file OUT with Diamond and can post-process it.
So I do not know where the problem is. The error message spots a mistake in line 5 of file .res.
I guess that is an internal file created by GiD to postprocess, isn't it?
It seems to me a file with printed values of temperatures in the nodes used to postprocessing.
Below the firsts 5 lines, I highlighted the line that apparently created the error:
GiD Post Results File 1.0
Result "Temperature" "Thermal-2D" 60.000000 Scalar OnNodes
Values
-858993460 1.00000e+000
-858993460 2.00000e+000
The files are huge, if you really want to take a look to it I can send you a link to download it.
Thanks for answering
Javier Unanua
Arup
t +34 91 523 92 76
From: gidlist-bounces at listas.cimne.upc.edu [mailto:gidlist-bounces at listas.cimne.upc.edu] On Behalf Of Eric Tonicello
Sent: 25 May 2012 08:28
Subject: Re: [GiDlist] Problems to postprocess in Safir
Hi, try to send me your file, I'll have a look at it.
Eric Tonicello
Eric Tonicello
Fire Safety Engineering Specialist, member of SSPShttp://www.vbsf.ch/section_romande, SFPEhttp://www.sfpe.org/, IAFSShttp://www.iafss.org/
direct: eric.tonicello at mp-ingenieurs.chmailto:eric.tonicello at mp-ingenieurs.ch
16, rue du Centre
CH-1023 Crissier
De : gidlist-bounces at listas.cimne.upc.edumailto:gidlist-bounces at listas.cimne.upc.edu [mailto:gidlist-bounces at listas.cimne.upc.edu]mailto:[mailto:gidlist-bounces at listas.cimne.upc.edu] De la part de Javier Unanua
À : gidlist at listas.cimne.upc.edumailto:gidlist at listas.cimne.upc.edu
Dear colleagues;
Kind regards
Javier Unanua
Arup
t +34 91 523 92 76
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120525/bc70691a/attachment-0001.htm
The .post.res is the file written by Safir to be read in GiD postprocess, but the file contents are wrong:
Values
the first row is the number of the node, and the second row the scalar value
instead of -858993460 must have a valid node number (of a node that exists)
Sent: Friday, May 25, 2012 9:58 AM
Hi Eric;
Values
Javier Unanua
Arup
t +34 91 523 92 76
www.arup.com
Eric Tonicello
Eric Tonicello
Fire Safety Engineering Specialist, member of SSPS, SFPE, IAFSS
16, rue du Centre
CH-1023 Crissier
De : gidlist-bounces at listas.cimne.upc.edu [mailto:gidlist-bounces at listas.cimne.upc.edu] De la part de Javier Unanua
Dear colleagues;
Kind regards
Javier Unanua
Arup
t +34 91 523 92 76
www.arup.com
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120525/3abd7475/attachment-0001.htm
Eric Tonicello
Javier,
Maybe it is a problem with GID10. Olivier said to me that the SAFIR to GOD
link had problem with this version
So I still use the 9.06 one.
I’ve send my job application to Barbara Lane and Jamie Stern-Gottfried in
Berlin
I wait for a sign from them.
Maybe you know Romain Buffat ? He worked in Madrid some years ago. He’s a
friend of mine.
See you Tuesday.
Eric
Envoyé : vendredi 25 mai 2012 09:58
Objet : Re: [GiDlist] Problems to postprocess in Safir
Hi Eric;
I guess that is an internal file created by GiD to postprocess, isn’t it?
to postprocessing.
error:
Values
Javier Unanua
Arup
t +34 91 523 92 76
Eric Tonicello
Eric Tonicello
16, rue du Centre
CH-1023 Crissier
Dear colleagues;
Kind regards
Javier Unanua
Arup
t +34 91 523 92 76
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120601/ed1a3f56/attachment-0001.htm
The .res file written by Safir is wrong,
Maybe the cause is that the Safir input is not as it expects because of the use of new GiD versions
You can try if you want to use for example GiD 9.0.6 (old GiD versions can be download from our web),
and if it works with this version, but not with GiD 11.0 version, please send me the model and the SAFIR problemtype (send directly to escolano at cimne.upc.edu instead to the gidlist )
and I will find the differences between GiD versions to let SAFIR work properly also with current GiD versions
Sent: Friday, June 01, 2012 11:02 AM
Javier,
Maybe it is a problem with GID10. Olivier said to me that the SAFIR to GOD link had problem with this version. So I still use the 9.06 one.
I've send my job application to Barbara Lane and Jamie Stern-Gottfried in Berlin. I wait for a sign from them.
Maybe you know Romain Buffat ? He worked in Madrid some years ago. He's a friend of mine.
See you Tuesday.
Eric
Hi Eric;
Values
Javier Unanua
Arup
t +34 91 523 92 76
www.arup.com
Eric Tonicello
Eric Tonicello
16, rue du Centre
CH-1023 Crissier
Dear colleagues;
Kind regards
Javier Unanua
Arup
t +34 91 523 92 76
www.arup.com
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120605/f833624f/attachment-0001.htm
Javier Unanua
Hi Enrique
Yes, the reason for such error was due to a bug in the Thermal2dres.exe file.
The people of the ULG sent me a corrected version of the file.
I am not sure about what could happen with previous versions of GiD, we have not a release 9.
Javier Unanua
Arup
t +34 91 523 92 76
From: gidlist-bounces at listas.cimne.upc.edu [mailto:gidlist-bounces at listas.cimne.upc.edu] On Behalf Of Enrique Escolano
Sent: 05 June 2012 12:45
and if it works with this version, but not with GiD 11.0 version, please send me the model and the SAFIR problemtype (send directly to escolano at cimne.upc.edumailto:escolano at cimne.upc.edu instead to the gidlist )
From: Eric Tonicellomailto:eric.tonicello at bluewin.ch
To: gidlist at listas.cimne.upc.edumailto:gidlist at listas.cimne.upc.edu
Javier,
Maybe it is a problem with GID10. Olivier said to me that the SAFIR to GOD link had problem with this version... So I still use the 9.06 one.
I've send my job application to Barbara Lane and Jamie Stern-Gottfried in Berlin... I wait for a sign from them.
See you Tuesday.
Eric
De : gidlist-bounces at listas.cimne.upc.edumailto:gidlist-bounces at listas.cimne.upc.edu [mailto:gidlist-bounces at listas.cimne.upc.edu] De la part de Javier Unanua
Hi Eric;
Values
Javier Unanua
Arup
t +34 91 523 92 76
From: gidlist-bounces at listas.cimne.upc.edumailto:gidlist-bounces at listas.cimne.upc.edu [mailto:gidlist-bounces at listas.cimne.upc.edu]mailto:[mailto:gidlist-bounces at listas.cimne.upc.edu] On Behalf Of Eric Tonicello
Eric Tonicello
Eric Tonicello
16, rue du Centre
CH-1023 Crissier
Dear colleagues;
Kind regards
Javier Unanua
Arup
t +34 91 523 92 76
GiDlist at listas.cimne.upc.edumailto:GiDlist at listas.cimne.upc.edu
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120605/c3132dd7/attachment-0001.htm
