Hello all,
I'm trying to run a 2D thermal analysis (problem type: SAFIR2011 -- Safir_Thermal_2d). When using the standard materials, the analysis runs just fine. I'm experiencing a problem when applying a new user material though. When I try to get into the postprocessing module after calculating, the following warning is displayed: Results file 'C:\path name\filename.post.res'is not found . Subsequently, no calculation data is available for postprocessing ('Warning: No results read' is displayed).
Does anyone know what causes this and how it can be fixed?
Thank you in advance,
Rob
____________________________________________________________
Electronic mail messages entering and leaving Arup business
systems are scanned for acceptability of content and viruses
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120120/7c1ddb38/attachment.htm
[GiDlist] User Material
Never had such issue.
Try to make the chane manually in the .IN file and run SAFIR from the shell
(or a dos windows) and see if it works.
You should contact safir at ulg.ac.be for more help.
Best reagrds
MP Ingénieurs Conseils SA
Eric Tonicello
Ingénieur civil HES / UTS
Spécialiste en Ingénierie de la Sécurité Incendie, membre
http://www.vbsf.ch/section_romande SSPS, http://www.iafss.org/ IAFSS
bureau: info at mp-ingenieurs.ch
direct: mailto:eric.tonicello at mp-ingenieurs.ch
16, rue du Centre
CH-1023 Crissier
tel: +41 21 636 09 02
fax: +41 21 635 09 40
mobile: +41 78 600 90 31
www.mp-ingenieurs.ch
De : gidlist-bounces at listas.cimne.upc.edu
[mailto:gidlist-bounces at listas.cimne.upc.edu] De la part de Rob Verhaegh
Envoyé : vendredi 20 janvier 2012 11:18
À : gidlist at listas.cimne.upc.edu
Objet : [GiDlist] User Material
Hello all,
I’m trying to run a 2D thermal analysis (problem type: SAFIR2011 à
fine. I’m experiencing a problem when applying a new user material though.
following warning is displayed: Results file ‘C:\path
name\filename.post.res’is not found . Subsequently, no calculation data is
available for postprocessing (‘Warning: No results read’ is displayed).
Rob
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20120120/63c53568/attachment.htm
Best reagrds
Eric Tonicello
16, rue du Centre
CH-1023 Crissier
Hello all,
Rob
