I would like to know if my root_atm.dat file format is correct.
I just want to impose a sinusoidal temperature to a surface during one year.
Though with this format, it doesn't seem to work. I don't understand why.
Regards.
root_atm.dat
Moderator: CODE_BRIGHT Team
root_atm.dat
- capture.png (1.73 KiB) Viewed 3557 times
- code_bright
- Contact:
Re: root_atm.dat
Dear tonireg,
Remember that you have an example of that file in the Code_Bright website:
https://www.etcg.upc.edu/recerca/webs/c ... ample/view
Remember also that the word "root" stands for the name of your model. For example, if your model name is tonireg, then the file name should be tonireg_atm.dat.
Alfonso
Alfonso
