Hi there,
I am using code bright for my research on THM process in soil pile interaction but I am getting some errors while using external load on THM coupling. I am facing the problem of 'EOF in line 1', could you please help me to get solution of this problem.
Thank you in advance
EOF too early
Moderator: CODE_BRIGHT Team
EOF too early
- THM practice.gid.zip
- (34.54 KiB) Downloaded 283 times
- THM Coupling Practice.gid.zip
- (2.7 MiB) Downloaded 270 times
- THM Coupling Practice with load on pile.gid.zip
- (131.25 KiB) Downloaded 276 times
- code_bright
- Contact:
Re: EOF too early
Hi khagendra!
As I expected, it seems you still need a lot of practice with the tutorials. I have take a look to your first problem and found a couple of mistakes. For example, you haven't set an initial porosity and in the boundary conditions it seems you want to prescribe the displacements, but you use a -1, and the only possibilities are 0 -not prescribed- or 1 -prescribed.
Besides, I strongly recommend you to don't use spaces in the name of your problem. You can use slashes (_) instead, for example.
Best wishes,
Alfonso
Best wishes,
Alfonso
