My first question is:
Can I *set var ElemsConec(4,int) = xNode, being xNode a node that I created or this var can never be changed?
This is because I created a new node and I want to change the old node of the element to the new node. Apparently it doesn't change.
My second question:
When I have a loop on elements inside a loop on nodes like for instance:
*set Cond y *nodes
*loop nodes *OnlyInCond
*set Cond z *elems
*loop elems *OnlyInCond
It doesn't work with the second condition before elems (it only works without the condition).
Why is that?
Thanks for your help,
Two question about the bas file
Re: Two question about the bas file
All .bas file commands only get information from GiD mesh, and its data. Dont't modify anything.
You can modify the mesh for example at Tcl scripting level, with the GiD_Mesh command (GiD_Mesh edit element ...)
(see help on Cutomization->Tcl and Tk extension->Special Tcl commands->Mesh
About nesting a elems loop on elements with a condition on another loop on nodes with another condition,
maybe there is some problem setting a condition inside a loop of other condition.
.bas syntax is too limitated. To do very complex things you could invoke from the *.bas a Tcl command with *tcl()
Tcl is a powerful and well-defined scripting language.
In any case nesting these loops could be a bad idea, it could be too expensive for big meshes.
Maybe you can find other approach to solve it in a cheaper way.
