Error creating result
warpino
Post by warpino »
Hi all,
I try to create a new result by. When I try and apply this to results stored in the Gauss points I have:
"result indices " list of indices "do not exist for result '" name of the result "' skipping it." In fact those indices are not in the .res file as they correspond to elements deleted during the analysis.
How can I solve this?
Best,
warpino
Re: Error creating result
Post by warpino »
Apparently results at the gauss points are not deleted when the corresponding elements are deleted. Is that normal?
Sorry, we don't understand well your explanation.
Wich version of GiD are you using?
(version 12.1.8d had a bug reading in postprocess results on gauss points in binary format, this has been fixed in version 12.1.9d)
Could you upload and attachment of your example?
Then we could examine it an determine if there is some bug in your files (to be fixed by you) or it is a bug of GiD (to be fixed by us).
