How to create point evolution graph ofa moving point
wenjie.duan
Post by wenjie.duan »
I want to create a point evolution graph to demonstrate the movement of a block which has large movement. But when I input the initial coord of the point, only the result of the first step is listed and nothing else. I guess it is because the block moving away from the position. How could I create a graph following the movement of the block?
Duan Wenjie
Re: How to create point evolution graph ofa moving point
When selecting the point you can specify a new coordinate x,y,z or an existing node id (by its integer id or clicking in screen)
To swap the selection mode between Join (click an existing node) or NoJoin (click a coordinate) you can use the keys <Ctrl>-a
(or select Join /NoJoin in the contextual menu while selecting)
beatrice1
Post by beatrice1 »
I’m a computer sciences student in FIGS Paris . I have the same problem listed above. I can’t manage to find how to coordinate the x,y, z node. Could you be more explicit ? Thanks in advance
