I am trying to mesh a 3D geometry and having trouble with some (complex) surfaces when importing it to GiD.
Surfaces seem not to follow the lines that form them. You can see it in this picture:
I have tried deleting the surfaces, then dividing the lines (without modyfing them) in several segments, then creating the surface again, and it seems to work, but it simply is not practical, and VERY time consuming.
The 3D body is right on the CAD system, and I am able to open it succesfully in two different CAD systems, so it seems like GiD is not dealing properly with some curved surfaces. I have tried changing import tolerance with no success.
I attach a picture of the right geometry as it is seen in the CAD software. It is just the same iges file I import into GiD. I have also tried with parasolid with the same problems.
Any hints on what causes this and a possible solution would be highly appreciated.
Thank you very much.
