merge results
kstn
merge results
Post by kstn »
Hi
I have 4 mesh files with node indexing start from 1 for each one. For each partition the mesh is displayed correctly. But when it's merged, the result became garbage. I think the reason is because GiD try to merge the same node id instead of create the new instances of it. Is there a work around for this case?
I attached my mesh file for checking this behaviour?
Giang Bui
slope_stability_3d.tar.gz
(70.3 KiB) Downloaded 735 times
kstn
Re: merge results
Post by kstn »
Hi
I solved this problem by renumbering the mesh consecutively
Bui
