I have the following problem,
when using 20 noded brick element, the order of nodes around the element is not consistent neither clockwise nor counterclockwise.
it writes the nodes in the corner first then the middle. therefore, the (swap) option does not work in this case.
Is it possible to change that to be consistent clockwise or counterclockwise order of nodes around the element.
Thank you
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20000802/0c8ead28/attachment.htm
[ GiDlist ] order of nodes around the 20 noded element!
