[ GiDlist ] nodal coordinates
Posted: Tue May 02, 2000 6:29 pm
by ramsan at stamp.cimne.upc.es
In the latest version, the tolerance for the z coordinate is much
smaller. Get the lattest beta in the 'GiD web page download Beta
versions' and this problem should be fixed.
maik at talkevax.ucsd.edu writes:
thanks for the prompt reply,
unfortunately it doesn't seem to work. I get three coordinates, but the
third one is always zero. I checked with the write mesh option and there
the z values are different from zero.
what else can I do?
regARDS Maik
At 11:18 AM 5/2/00 +0200, you wrote:
maik at talkevax.ucsd.edu wrote:
I'm dealing with surfaces of sliders in computer harddrives. I' using GiD
for meshgenerating. The surfaces are three dimensional. when I use the
Write Mesh command, my nodes have Three coordinates, if I use the command
*loop nodes
*NodesNum *NodesCoord
*end
in the ".bas" file for the same model Gid writes only the x & y coordinate.
How can I solve this problem.
The differences in the level of two adjacent surfaces are pretty small.
(0.001 mm)
Is there an option that has two be set?
I don't have problems if the surfaces levels are bigger.
Maik Duwensee
Maik Duwensee
The problem is that GiD uses an epsilon on the Z axis to determine if
the problem is a 2D one or a 3D one (if all the geometry is defined
inside this epsilon, the problem is a 2D one).
But you can get the three coordinates of the nodes with something like this:
*loop nodes
*NodesNum *NodesCoord(1) *NodesCoord(2) *NodesCoord(3)
*end nodes
Miguel A. de Riera Pasenau miguel at cimne.upc.es
http://gid.cimne.upc.es
Maik Duwensee
____________________________________________
University of California San Diego
Center for Magnetic Recording Research, 0401
9500 Gilman Drive
La Jolla, CA 92093-0401
mail: maik at talkelab.ucsd.edu
Phone: (858)-534-2882
http://www-talkelab.ucsd.edu/
Centre Internacional de Mètodes Dr. Ramon Ribó
Numèrics en Enginyeria
ramsan at cimne.upc.es
C/ Gran Capitan s/n,
Modulo C1, Campus Norte UPC, tel. +34 93 401 74 03
E-08034 Barcelona, Spain fax. +34 93 401 65 17
