[GiDlist] z coord for nodes
Posted: Mon Dec 17, 2001 10:51 am
by Aldo Ghisi
I need the _value_ of z coordinate for a set of nodes: I use this in a
calculus for obtaining the nodal forces for an hydrostatic load.
I try with NodesCoord(3,real), but it doesn't work (I think this is just a
write command for nodes).
Can anyone help me?
Thank you in advance.
Aldo Ghisi
ALDO GHISI
Department of Structural Engineering
Politecnico di Milano
Piazza Leonardo da Vinci 32, 20133 Milano, Italy
Tel.: +39 02 2399 4218
Fax.: +39 02 2399 4220
E_mail: aldo.ghisi at polimi.it
Posted: Mon Dec 17, 2001 12:36 pm
To obtain the z coordinate of a node in the *.bas file, the command NodesCoord
must be inside a loop over nodes, for example
*loop nodes
*NodesCoord(3,real)
set var znode=NodesCoord(3,real)
*end nodes
You can also implement the hydrostatic condition whit a #FUNC# field of the condition
the value of this field is auto-calculated for each node/element
(can use x,y,z of the node and another field values)
For example, in the *.cnd file:
NUMBER: 1 CONDITION: Hydrostatic
CONDTYPE: over surfaces
CONDMESHTYPE: over nodes
QUESTION: Fuid_z:
VALUE: 0
QUESTION: Density
VALUE: 0
QUESTION: Pressure#FUNC#((Cond(1,REAL)-z)*Cond(2,REAL))
VALUE: Automatic
END CONDITION
And in the bas file:
*Set Cond Hydrostatic *nodes
*loop nodes *OnlyInCond
*cond(Pressure)
*end nodes
Sent: Monday, December 17, 2001 10:47 AM
Subject: [GiDlist] z coord for nodes
Can anyone help me?
Aldo Ghisi
ALDO GHISI
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20011217/3c86c0ea/attachment.htm
Posted: Mon Dec 17, 2001 2:59 pm
by Aldo Ghisi
Hi Enrique,
sorry, I already try with this (it was already asked by someone other in
the mailing list), but I cannot get the result I expected.
GiD seems not to accept the z-coord. These are my files .cnd and .bas
NUMBER: 10 CONDITION: Hydrostatic
QUESTION: Z_Water:
VALUE: 1.
QUESTION: Density:
VALUE: 1000.
VALUE: Automatic
END CONDITION
*set cond Hydrostatic *nodes
*nodesnum *cond(Pressure,real)
*end nodes
I obtain this (first column are node numbers) in output:
13 1000.000000
19 1000.000000
23 1000.000000
24 1000.000000
26 1000.000000
27 1000.000000
It seems to me that GiD makes at any time only the calculus with z = 0
Where is my error?
Thank you in advance and regards
Aldo
P.S. If you need it, this is my mesh (File-Import/Export-Write mesh):
begin next row
MESH dimension 3 ElemType Hexahedra Nnode 8
Coordinates
1 0 0 0
2 2.5 0 0
3 0 2.5 0
4 0 0 2.5
5 2.5 0 2.5
6 0 2.5 2.5
7 2.5 2.5 0
8 2.5 2.5 2.5
9 5 0 0
10 0 5 0
11 0 0 5
12 2.5 5 0
13 5 2.5 0
14 2.5 0 5
15 0 5 2.5
16 0 2.5 5
17 5 0 2.5
18 2.5 5 2.5
19 5 2.5 2.5
20 2.5 2.5 5
21 0 5 5
22 5 0 5
23 5 5 0
24 5 5 2.5
25 2.5 5 5
26 5 2.5 5
27 5 5 5
end coordinates
Elements
1 8 18 12 7 6 15 10 3
2 5 8 7 2 4 6 3 1
3 20 25 18 8 16 21 15 6
4 14 20 8 5 11 16 6 4
5 19 24 23 13 8 18 12 7
6 17 19 13 9 5 8 7 2
7 26 27 24 19 20 25 18 8
8 22 26 19 17 14 20 8 5
end elements
end previous row
command NodesCoord
*loop nodes
*NodesCoord(3,real)
*end nodes
the condition
QUESTION: Fuid_z:
VALUE: 0
QUESTION: Density
VALUE: 0
VALUE: Automatic
END CONDITION
*cond(Pressure)
*end nodes
From: "Aldo Ghisi" mailto:ghisi at stru.polimi.itghisi at stru.polimi.it
To: mailto:gidlist at gatxan.cimne.upc.esgidlist at gatxan.cimne.upc.es
Can anyone help me?
Aldo Ghisi
ALDO GHISI
E_mail: mailto:aldo.ghisi at polimi.italdo.ghisi at polimi.it
mailto:GiDlist at gid.cimne.upc.esGiDlist at gid.cimne.upc.es
Posted: Mon Dec 17, 2001 4:54 pm
Try to update your GiD version to the last beta in the web page (for windows
actually the last is the 6.2.0b).
Note: The registration code of the 6.1.3 official version is valid for all
6.x betas.
I' tried your files and it works i my version.
I' attach the problem type "Aldo.gid" and your cube test "TestAldo.gid".
The Calculation file output obtained is:
1 1000
2 1000
3 -250
4 1000
5 1000
6 1000
7 -1500
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20011217/a66a9687/attachment.bin
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20011217/a66a9687/attachment-0001.bin
Posted: Mon Dec 17, 2001 6:08 pm
by Aldo Ghisi
I upgrade to GiD6.2.0b and now it works. Thanks, Enrique!
Aldo
6.x betas.
1 1000
2 1000
3 -250
4 1000
5 1000
6 1000
7 -1500
