[GiDlist] Model with linear elements with 2 and 3 nodes
Posted: Tue Dec 04, 2001 11:28 am
by Valdenir de Souza Junior
Dear GiD list members,
I am trying to model a 3D frame, which has beam elements, with 3 nodes and
truss elements, with 2 nodes. If I use the option "Meshing/Quadratic
elements/Quadratic", only linear elements with 3 nodes will be generated
for the whole model. On other hand, using the option "Meshing/Quadratic
elements/Normal", only linear elements with 2 nodes will be generated for
the whole model.
Is there a procedure to create 2 and 3 nodes in a single model? I am using
the 6.1.2 version of GiD.
Thanks in advance
Centro de Mecânica Aplicada e Computacional - CEMACOM
Federal University of Rio Grande do Sul - UFRGS
Porto Alegre, Brazil
Posted: Tue Dec 04, 2001 12:03 pm
In GiD, all the mesh is considered as quadratic or linear.
In order to have together both types it is necessary to make some "trick".
For example, a condition named "Truss" can be assigned to some lines, to
mesh all quadratic , but in the elements with this condition only two nodes
for the calculation are written, ignoring the central node.
Another possibility would be:
1- Mesh the linear elements
2- Write the mesh in disc (Files-Import/Export-WriteMesh)
3- Mesh the quadratic elements
4- Reload the linear mesh (Files-Import/Export-MeshRead) option
AddNoShare
5- Collapse the mesh to join superposed nodes.
From: "Valdenir de Souza Junior" souzajr at gmx.net
To: GiDlist at gatxan.cimne.upc.es
Sent: Tuesday, December 04, 2001 11:23 AM
Subject: [GiDlist] Model with linear elements with 2 and 3 nodes
the whole model.
Thanks in advance
[GiDlist] A bug in version "6.2b"..?
Posted: Thu Dec 06, 2001 12:57 pm
by Rajab Said
It seems as if the "Multiple windows" option is
not working in the recent beta version..?! GiD
crashes with "Segmentation fault" whatever window
configuration is chosen.
I am running it on an SGI O2 workstation under IRIX 6.5
_____________________________________________________________
Rajab Said,
Senior Research Assistant,
Department of Civil Engineering, University of Wales Swansea,
Singleton Park, Swansea. SA2 8PP.
Fax : (44)1792-295676_________Tel : (44)1792-205678 Ext.4183
Posted: Fri Dec 07, 2001 3:59 pm
Thanks to inform to us into the problem.
We already know this bug, in the next version will be corrected.
(in the Windows version it not crash).
Sent: Thursday, December 06, 2001 12:56 PM
Subject: [GiDlist] A bug in version "6.2b"..?
Rajab Said,
