[GiDlist] gid 6.2b don't execute *.bat file
pachevalier at netcourrier.com
Post by pachevalier at netcourrier.com »
When i rename command.exe to _command.exe, that's ok.
I join the file tn_meca.bat
Regards.
Patrick Chevalier.
Sent: Friday, November 30, 2001 7:46 PM
Subject: Re: [GiDlist] gid 6.2b don't execute *.bat file
please, send us the file "problemtype.bat" to check it.
Try to rename the file command.exe (located in the same directory of
gid.exe) to _command.exe (then the file "problemtype.bat" is executed as
GiD the old mode versions).
If your input file *.dat must be in a fixed format, check if this file is
correct with this format (take care of the spaces!
Sent: Friday, November 30, 2001 7:19 PM
Subject: [GiDlist] gid 6.2b don't execute *.bat file
I downloaded gid 6.2b and it didn't execute the file tn_meca.dat of my
problem type. Gid output only the *.dat file and don't continue the
script.
This problem appear with windows98 and windows NT4 too. There isn't
problem
with gid6.1.5b.
What's append?
Regards.
Patrick Chevalier.
NetCourrier, votre bureau virtuel sur Internet : Mail, Agenda, Clubs,
Toolbar...
Web/Wap : www.netcourrier.com
Téléphone/Fax : 08 92 69 00 21 (0,34 E TTC/min - 2,21 F TTC/min)
Minitel: 3615 NETCOURRIER (0,15 E TTC/min - 1,00 F TTC/min)
NetCourrier, votre bureau virtuel sur Internet : Mail, Agenda, Clubs, Toolbar...
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20011202/6821aed7/attachment.obj
