There are several possibilities:
- The simplest one is go to postprocess and read the file.
Maybe it is necessary to use a recent beta for this.
- In the preprocess:
Open the right button toolbar (Utilities-Graphical-Toolbar)
and use: Data Materials DrawMaterials DrawAll
- Also in the right buttons, use: View Layers Material
Commands accessed with the right buttons toolbar can also be
written in the command line.
[mailto:owner-gid at gatxan.cimne.upc.es]En nombre de Mark Smith
Enviado el: viernes, 19 de octubre de 2001 13:46
Para: Gidlist (E-mail)
Asunto: [ GiDlist ] Read mesh
I am reading in a triangular mesh (using mesh read) which has a material
number associated with each element. i.e. in the elements part of the mesh
file I have:
element number node1 node2 node3 material
The mesh imports OK but I cannot find a way of viewing the material ID of
each element. The reference manual suggests there is a way of forcing each
material number onto a unique layer but I cannot find a way of doing it.
Any help will be most appreciated.
Mark
Mark Smith (E-mail).vcf
person.
