[ GiDlist ] (*.falvia.res) format..?
Posted: Fri Sep 28, 2001 11:36 am
I have been trying to learn using GID as a post processing
environment. I am interested in the `new' file format
(*.falvia.res) only. So as a start, I wanted to try out the
example available in the online manual:
1- Create the mesh file (*.falvia.msh)
2- Create the result file (*.falvia.res)
3- Load up the mesh file in the 'Preprocess' mode
using the (Files -- Import -- Mesh Read).
4- Move to the 'Postprocess' mode.
5- Try to load up the result file using (Open):::=
GiD complains about reaching the "EOF" in the
second line...!?
6- Assuming there is a problem in reading the blank lines,
I changed the blank lines to comments lines:::=
Gid complains:
(Node out of range: in this line: 9 - Reading Results.)
Any comment is appreciated...
Many thanks
Rajab
P.S.
* Both files have been stored under one directory with
the same project name.
** While I was using (copy and past) to create the files,
I noticed a 'typing mistake' in one of the keywords
(i.e. Ntural instead of Natural). Correcting this has not
changed the above at all..
*** I am using (Gid 6.1.2 Academic version) on an SGI workstation,
and I have not experienced any problem with the examples
were included in the download files, or any other file
I have created (i.e. different type of meshes only without
any associated solution).
second line...!?
Gid complains:
Many thanks
Rajab
P.S.
