[ GiDlist ] trouble creating an mesh for third-party soft
Posted: Thu Sep 13, 2001 4:32 pm
1) *nnode allwais returns the number of nodes of the element with the
highest number, máx(3,4)=4 in this case.
in the loop over elements, it is "a priori" known the type of element, and
the number of nodes of this element (e.g. for linear triangle=3 and for
quadratic triangle =6)
*set elems(Triangle)
*loop elems
*if(isquadratic)
*set var nnodeelem=6
*else
*set var nnodeelem=3
*endif
nb_nodes=*nnodeelem
*end elems
2) *ElemsConec is also correct for triangle elements (named "faces" in your
mail).
It is possible that "gmesh" requires the triangle connectivities in another
order: instead of ABC, CBA. It is possible to write the connectivities in
any order:
*loop elems
*ElemsConec(3) *ElemsConec(2) *ElemsConec(1)
*end elems
3) Please, send a sample (and the problem type) where re-running gid, it
change the material number of the elements. Please, specify the GiD version
number (see Help-About)
Best Regards.
The GiD Team
From: "trophime christophe" trophime at labs.polycnrs-gre.fr
To: "Gid" gidlist at gatxan.cimne.upc.es
Sent: Thursday, September 13, 2001 2:00 PM
Subject: [ GiDlist ] trouble creating an mesh for third-party soft
I am trying to use Gid as a pre-processor for getdp.
I import a geometry from an Iges file. I would like to
create a mesh of this sort :
$NOD
number_of_nodes
node_id coord1 coord2 coord3
$ENDNOD
$ELM
number_of_elements
elm_id elm_type elm_mat unused nb_nodes connectivity
$ENDELM
So I have defined a new problemtypes called getdp with
the following template file :
*set elems(all)
$NOD
*npoin
*loop nodes
*format "%6i%15.5e%15.5e%15.5e"
*NodesNum *operation(1.e-3*NodesCoord(1,real))
*operation(1.e-3*NodesCoord(2,real))
*operation(1.e-3*NodesCoord(3,real))
*end nodes
$ENDNOD
$ELM
*nelem
*set elems(Tetrahedra)
*set var elmtype=4
*set var elmunused=0
*loop elems
*format "%10i%5i%5i%5i%5i%10i%10i%10i%10i"
*ElemsNum *elmtype *ElemsMat *elmunused *nnode *ElemsConec
*end elems
*set var elmtype=3
*loop elems
*format "%10i%5i%5i%5i%5i%10i%10i%10i"
*end elems
$ENDELM
Just one more remark: I NEED to have information about "surfaces"
included into
my mesh file. To do that I build a .mat file which includes my fake
materials to retrieve
"elm_mat" for both elements and faces. Then I instruct Gid to create the
mesh using the Mesh Criteria over
surfaces to have acces to the faces in "elems".
My problem is first that for triangles *nnode give me 4 instead of 3!
Second when I tried to see using gmsh my "getdp mesh" the volume is fine
but the surfaces are completly corrupted so I wonder if my *ElemsConec
is wrong for faces...
Third if I rerun the gid from a saved session I don't get the same
"elm_mat" for my faces?
Could you help me out? (May be I'm doing something wrong?)
I am using an eval version of Gid which expires after the 3rd october...
I wish a quick answer
if it's possible.
Thanks for any help
*loop elems
*if(isquadratic)
*else
*endif
nb_nodes=*nnodeelem
*end elems
mail).
any order:
*loop elems
*end elems
Best Regards.
The GiD Team
$NOD
number_of_nodes
$ENDNOD
$ELM
number_of_elements
$ENDELM
*set elems(all)
$NOD
*npoin
*loop nodes
*end nodes
$ENDNOD
$ELM
*nelem
*set var elmtype=4
*loop elems
*end elems
*set var elmtype=3
*loop elems
*end elems
$ENDELM
included into
if it's possible.
Thanks for any help
