[ GiDlist ] erosion of elements?
Posted: Tue May 15, 2001 5:47 pm
Yes, during the analysis you can completely modify your mesh. Indeed, in
this case you are forced to write the new element conectivities and node
numbers in the 'filename.flavia.msh', as well as use the new node list in
the 'filename.flavia.res'.
On the other hand, if you don't modify your mesh during the analysis, only
the 'filename.flavia.res' has to be created.
De: owner-gid at gatxan.cimne.upc.es [mailto:owner-gid at gatxan.cimne.upc.es]En
nombre de Matthew Profit
Enviado el: martes, 15 de mayo de 2001 18:32
Asunto: [ GiDlist ] erosion of elements?
Is it possible to delete elements within gid?? for erosion or fracture
problems.
I've created the initial mesh in gid format for the post processor to
read, under the name "filename.flavia.msh". This file reads in the number of
initial elements for the problem. If during the analysis some elements are
deleted is it possible to update the number of elements as the analysis is
running? Within the file named "filename.flavia.res".
Thanks in advance,
Matthew
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20010515/0b0be493/attachment.htm
problems.
Thanks in advance,
Matthew
