[ GiDlist ] Problem importing results to GID
Posted: Tue Mar 20, 2001 3:43 pm
I'm having difficulties importing results to GID (Version 6.1.2).
I do the calculations outside GID, in my own thin-shell routine.
I can import the mesh with no problem, but when importing the results using
the format found on the reference manual, GID doesn't recognizes the phrase
(in the project.flavia.res file):
Result "xxxx" "zzzz" 1 Vector OnGausspoints etc.
By skipping that phrase, I managed to overcome this and already can
represent and visualize the displacements on the nodes, but can't import the
stress's, that are calculated in the center of the elements. I need to
"tell" GID that the results are in a Gauss Point in the center of the
element. It accepts the definition off the gauss point set, but doesn't
assign the results to that set, because it doesn't reads this phrase.
There are also some minor bugs, but in this moment, this is the really
important part.
Really looking forward into buying the software. Already altered the output
of some programs to GID format (quite easy to do), but now it doesn't read
the stresses, witch are fundamental!!!
Thanks for you time
Ricardo Resende
Departamento de Barragens (Dam´s Department), LNEC, Portugal
Type: application/ms-tnef
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20010320/a00cae32/attachment.bin
important part.
Thanks for you time
Ricardo Resende
