[ GiDlist ] Triangular element
Nguyen, Binh
Post by Nguyen, Binh »
Hi;
Thanks for the info to pin-point it out. Now I can generate the surface mesh
using TRIANGLE type.
BTW: I'm a new GID learner
Cheers
Binh
-----Original Message-----
Sent: Friday, 2 March 2001 8:39
Subject: RE: [ GiDlist ] Triangular element
In addition to my last message, you can find the 'mesh' commands in the
following menu:
Meshing - Mesh Criteria - No Mesh - Volumnes (and you have to select the
volumes)
Meshing - Mesh Criteria - Mesh - surfaces (and you have to select the
surfaces)
J
[mailto:owner-gid at gatxan.cimne.upc.es]On Behalf Of Nguyen, Binh
Sent: Friday, March 02, 2001 12:34 AM
To: 'gidlist at gid.cimne.upc.es'
Subject: [ GiDlist ] Triangular element
Hi;
I have had trouble in generating mesh on a surface. I
realised that in order
to generate triangular elements (instead of tetrahedra by
default), the
surface has to be structured.
Anyway, I'm wondering if I could produce a triangular mesh
surface on a
sphere or a cylinder or any enclosed volumes.
Binh
