[GiDlist] How to output result in binary format?
ieea
[GiDlist] Find a tcl process to assign condition to a point
Post by ieea »
Dear All,
I wish to write a tcl procedure to assign a condition to a point.
After having created a single point (number 1) I used this command:
.central.s process data conditions assign 1 escape \
close
but it seems to be a wrong command.
Can you help me please.
G.W.R.Geis
Aleix Valls
Post by Aleix Valls »
Try to use this command:
.central.s process escape escape escape escape escape Data \
Conditions AssignCond "Name_of_the_condition" "ID_of_point"
escape
Normally, it is a good trick use a sequence of "escape's" before begin
with commands (with this escape sequence you bring GiD to the initial
state).
A good tool to see how GiD commands have to be written, it is use the
GiD batch file. More information can be found in GiD help.
Bye,
Aleix
[mailto:gidlist-admin at gatxan.cimne.upc.es] En nombre de ieea
Enviado el: sábado, 19 de octubre de 2002 17:11
Para: GiDlist at gatxan.cimne.upc.es
Asunto: [GiDlist] Find a tcl process to assign condition to a point
Dear All,
close
G.W.R.Geis
Post by Enrique Escolano »
Before the point or points number it is needed the name of the condition to
assign, for example Point_Constraint:
(and before to assign any condition it is needed to load a problem type with
this condition defined over points)
For example:
.central.s process escape escape escape escape data conditions assigncond
Point_Constraint 1 escape
About your previous questions: You can create an auxiliary line to define
your antenna orientation.
put your line in a "special" layer and ignore this line for the mesh
generation or another operations.
To: GiDlist at gatxan.cimne.upc.es
Sent: Saturday, October 19, 2002 5:11 PM
Subject: [GiDlist] Find a tcl process to assign condition to a point
Dear All,
close
G.W.R.Geis
Ramon Ribó
Post by Ramon Ribó »
If you want to assign the condition with values different from
the defaults, you should use something like the following:
.central.s process escape escape escape escape data cond assign \
$_CndName change $Values $l escape
In this case, this command can be found in DataWindows.tcl
You can find a lot of information just by investigating the GiD TCL
scripts.
Regards and happy Christmas to everybody,
[mailto:gidlist-admin at gatxan.cimne.upc.es]En nombre de Enrique Escolano
Enviado el: jueves, 19 de diciembre de 2002 19:24
Asunto: Re: [GiDlist] Find a tcl process to assign condition to a point
For example:
Dear All,
close
G.W.R.Geis
