[GiDlist] Problem with units file costumization
Posted: Fri Jun 28, 2002 7:36 pm
1) I've written a template file (tochnog.bas, tochnog.mat, tochnog.prb, tochnog.cnd) in GID 6.1.2 for the Tochnog solver. Now I'm trying to implement a units file (tochnog.uni) as proposed in the reference manual, but it doesn't work. First I tried to write a units file similar to the units.gid file which is inside the scripts directory. GID doesn't write any of the defined units from a units system into the window triggered by the menu data units. I've tried everything to make these units appear. I guess I didn't understand how this units file exactly works.
The new version of GID does recognize these units. I guess a change was made to the units.tcl file, but I couldn't figure out why these units don't appear in the GID version 6.1.2.
I also tried to use the units field in my configuration files to make these defined units appear, for intance in the materials file, but GID 6.1.2 didn't recognize this units field declaration (#UNITS#).
Could anyone help?
regards, Andreas
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020628/6139997c/attachment.htm
Could anyone help?
regards, Andreas
