Dear GiDteam.
I downloaded the recent course notes and installed the VRMLout problem type
but it seems that GiD orders the nodes of triangular elements in a way which
is not 100% vrml IndexedFaceSet compatible (some elements appear
invisible) swapping the node ordering on certain elements solves the
problem.
I realise that the VRMLout was only an example problem type but any
suggestions about element renumbering would be helpful.
Mark
Version: 6.0.350 / Virus Database: 196 - Release Date: 17/04/02
+44 (0)1480302100
http://www.linx.co.uk/
person.
[GiDlist] VRMLout and GiD6.3.0b
The VRML viewers only show the front face of the triangles, but not the back
face.
In GiD, you can swap group surface normals to force a desired orientation,
but if it is
desired view front and back it is necessary write two repeated triangles
with opposite normals?
I' unknow the VRML order to show the thwo faces.
Sent: Monday, April 29, 2002 6:51 PM
Subject: [GiDlist] VRMLout and GiD6.3.0b
Dear GiDteam.
type
which
problem.
Mark
+44 (0)1480302100
person.
Linx.
face.
but if it is
Dear GiDteam.
type
which
problem.
Mark
+44 (0)1480302100
person.
Linx.
