[GiDlist] (no subject)
Posted: Thu Apr 11, 2002 12:31 pm
by Mel Bernstein
I'm trying to mesh a solid with a hole. I do the following:
1. Create the main volume
2. Create the hole volume
3. Choose Geometry|Create|Volume|Hole and choose first the main volume and
the the hole volume as prompted.
4. I then try to generate the mesh and the following message appears:
Stopped meshing near point: 1.414214 0.471405 9.166667
Elements generated: 122. Faces in last front: 142
Status error for tetrahedra mesher is: Couldn't find point
What am I doing wrong?
Mel.
_________________________________________________________________
MSN Photos is the easiest way to share and print your photos:
http://photos.msn.com/support/worldwide.aspx
Posted: Thu Apr 11, 2002 2:45 pm
Choose another Meshing Preferences (Utilities-Preferences)
- Try for example: mesher=RSurf, Automatic correct sizes=Selected, and
Unstructured size transitions=0.7
- Choose a mesh size appropiate to the body size.
You can also assign a specified unstructured size to points, lines, surfaces
or volumes.
If this fail, send us the sample to check it
(indicate your GiD version, see Help-About)
Sent: Thursday, April 11, 2002 1:16 PM
Mel.
