[GiDlist] Gidpoints in Hexahedra element
Posted: Thu Mar 14, 2002 7:49 pm
by Jonas Forssell
I'm running the latest beta 6.2.0d of GID.
I want to show data on hexahedra elements with 8 nodes and 8 integration
points, but the
output looks like the position of the gausspoints are not according to my
assumption
(gausspoint 1 close to node 1 and so on).
Is there somwhere an explanation on this?
/Jonas Forssell, Gothenburg, Sweden
_________________________________________________________________
MSN Photos is the easiest way to share and print your photos:
http://photos.msn.com/support/worldwide.aspx
Posted: Mon Mar 18, 2002 4:55 pm
by Miguel A. de Riera Pasenau
Yes, the gauss internal gauss points used for hexahedrals are the ones
showed in the following picture, which corresponds to the gauss points 'PG 8 int'
of the attached example 'hex.msh/.res'.
To get the order you want, you can enter the natural coordinates in the
order you need, like the gauss points 'PG 8 given' in the same example file.
As the results values are the numbers of the gauss points, when you look at
the 'results labels', you will see the number of the gauss point.
the gauss points pixtures for 3d elements will be add very soon to the manual.
thanks
points, but the
assumption
Type: image/png
Url : http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020318/32f5b215/attachment.png
mesh "hexahedra 8" dimension 3 elemtype hexahedra nnode 8
coordinates
1 0.0 0.0 0.0
2 1.0 0.0 0.0
3 1.0 1.0 0.0
4 0.0 1.0 0.0
5 0.0 0.0 1.0
6 1.0 0.0 1.0
7 1.0 1.0 1.0
8 0.0 1.0 1.0
end coordinates
elements
1 1 2 3 4 5 6 7 8 1
end elements
GiD Post Results File 1.0
GaussPoints "PG 8 int" elemtype hexahedra "hexahedra 8"
Number of Gauss Points: 8
Natural Coordinates: Internal
End gausspoints
GaussPoints "PG 8 given" elemtype hexahedra "hexahedra 8"
Natural Coordinates: Given
-0.577350269189626 -0.577350269189626 -0.577350269189626
0.577350269189626 0.577350269189626 -0.577350269189626
-0.577350269189626 0.577350269189626 -0.577350269189626
-0.577350269189626 -0.577350269189626 0.577350269189626
0.577350269189626 0.577350269189626 0.577350269189626
-0.577350269189626 0.577350269189626 0.577350269189626
End gausspoints
result "prueba PG" "test" 1 Scalar OnGaussPoints "PG 8 int"
values
1 1
2 2
3 3
4 4
5 5
6 6
7 7
8 8
end values
result "prueba PG" "test" 1 Scalar OnGaussPoints "PG 8 given"
values
1 1
2 2
3 3
4 4
5 5
6 6
7 7
8 8
end values
