[GiDlist] entities references
Zoubir Khatir
Post by Zoubir Khatir »
Is it possible to get the entities references (volumes, surfaces,...) in
the entry data file ?
I would like to associate each mesh element to its entity. exemple :
element mesh number x belongs to the volume number y...
I am working wit GiD 6.2.0.c .
Thank you for any help...
Zoubir Khatir,
Laboratoire des Technologies Nouvelles (LTN)
INRETS, 2. Av. Malleret-Joinville, 94114 Arcueil Cedex
Tel: (33).01.47.40.73.34 Fax:(33).01.45.47.56.06 mail: khatir at inrets.fr
web: www.inrets.fr
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020314/733a7a7e/attachment.htm
Post by Enrique Escolano »
You can dowload from the web page http://gid.cimne.upc.es the Advanced course documentation of the GiD Courses previous to the 1st Conference on Advances and Applications of GiD (Barcelona 20, 21 and 22 February 2002).
Inside the Word document: A2-Problem type details.doc, see the chapter 5. "INSTRUCTION *tcl IN THE .bas FILE".
This is the chapter:
5. INSTRUCTION *tcl IN THE .bas FILE
In the .bas file, that GiD takes as a template for writing the file for calculus, it can be used a special *tcl(parameter) function, with which we can make complicated operations in tcl, or for example we can access to data of GiD obtained from tcl with the info command.
In the next example we want to obtain information of the geometric entities of GiD. Without the tcl instruction, from the *.bas file there's only access to mesh data, but not to the geometric entities.
For example, imagine we need to know the surface to which the elements belong and which is the entirely definition of that surface.
It can be used the field #FUNC(NumEntity) for checking with a condition on the entity ( that will be its number as entity ) every element which comes from that entity, so we can know the entity from which comes every mesh element. We can use the *.tcl instruction for writing the information of that surface, as showed in this example GeomInfoBas.tcl:
GeomInfoBas.cnd file:
NUMBER: 1 CONDITION: Surface_Id
CONDTYPE: over surfaces
CONDMESHTYPE: over face elems
QUESTION: Num_Entity#FUNC#(NumEntity)
VALUE: 0
STATE: HIDDEN
END CONDITION
(Note that there can be created occult fields with STATE:HIDDEN)
GeomInfoBas.tcl file:
proc InitGIDProject { dir } {
proc EndGIDProject {} {
proc NumSurfaces { } {
set a [.central.s info list_entities Status]
regexp -nocase {number of surfaces: ([0-9]+)} $a none num
return $num
proc WriteAllSurfacesInfo { } {
return [.central.s info list_entities Surfaces 1:[NumSurfaces]]
proc WriteSurfaceInfo { num } {
return [.central.s info list_entities Surfaces $num]
GeomInfoBas.bas file:
NUM_ELEM FACE_CONECTIVITIES NUM_SURFACE
*set cond Surface_Id *elems *CanRepeat
*loop elems *OnlyInCond
*elemsnum *elemsconec *Cond(Num_Entity,int)
*end elemsn
INI SURFACES
*tcl(WriteAllSurfacesInfo)
END SURFACES
*# sample to write oly the surface 1 description
*# *set var num=1
*# *tcl(WriteSurfaceInfo *num)
In the tcl file there have been defined three entities: NumSurfaces returns the number of surfaces of the model, whereas WriteSurfaceInfo prints in the calculus file the definition of the surface indicated in its parameter "num"; finally, WriteAllSurfacesInfo has no parameters and prints all surfaces.
In the .bas file there are written the elements and the origin surface number, with *Cond(Num_Entity,int), and then there are listed all surfaces.
Here are shown in two columns an arbitrary file example, obtained with that problem type.
1 18 19 23 1
2 19 21 26 1
33 38 34 37 1
34 19 18 14 2
60 4 7 10 2
INI SURFACES
NURBSURFACE
Num: 1 HigherEntity: 0 conditions: 1 material: 0
LAYER: Layer0
NumLines: 4
Line: 6 Orientation: DIFF1ST
Line: 5 Orientation: DIFF1ST
Line: 1 Orientation: SAME1ST
Line: 7 Orientation: DIFF1ST
Number of Control Points= 2 2 Degree= 1 1
Point 1,1 coords:-5.081426,4.132659,0.000000
Point 1,2 coords:-5.081426,-0.799912,0.000000
Point 2,1 coords:1.745159,4.132659,0.000000
Point 2,2 coords:1.745159,-0.799912,0.000000
Number of knots in U= 4
knot 1 value=0.000000
knot 2 value=0.000000
knot 3 value=1.000000
knot 4 value=1.000000
Number of knots in V= 4
Non rational
IsTrimmed: 1
Center: -1.654929 1.619719 0.000000
Normal: 0.000000 0.000000 1.000000
END NURBSURFACE
END SURFACES
Sent: Thursday, March 14, 2002 9:15 AM
Subject: [GiDlist] entities references
Is it possible to get the entities references (volumes, surfaces,...) in the entry data file ?
I would like to associate each mesh element to its entity. exemple : element mesh number x belongs to the volume number y...
Zoubir Khatir,
web: www.inrets.fr
URL: http://listas.cimne.upc.edu/pipermail/gidlist/attachments/20020314/b77b2a2a/attachment.htm
